VU TV Vibe 50 inch
LRGOPAL
There is a peculiar problem on my new VU vibe 50 inch google TV. The ARC port connected to my Blaupunkt SBW100 once the external speaker is on and changed to HD mode then the TV video goes away and back after 2-3 seconds. Again on turning off the external the sound to tv does not restore till power is turned off the external. Suggestions pls.
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
  • Is this happening now first time when you connected? Or never face this issue until now?
  • Have you tried with a different HDMI cable? Sometimes the cable is the culprit.
  • Would suggest trying out trouble shootings steps available in the Owner's Manual - Blaupunkt SBW100.
If you can provide more details, others can chime in. Suggest you to post this issue under the other specific threads (Televisions) where it will get more attention and possible solutions. (https://www.hifivision.com/forums/television.13/)
All the best!
