wadia itransport
vilfy
hi everybody,
wanted to know that if i connect my ipod 160 gb through wadia itransport to marantz amplifier using normal cables (from wadia's audio out to marantz's aux in)..... will i get the same sound quality (equivalent to 16 bit/44khz digital output which only wadia is able to extract from ipods)
or will i have to use some special cables or some special equipment to get the best possible sound quality?
please advise / guide.
hi everybody,
I checked a few sites including that of Wadi. In the FAQ, wadia provides the following answers:
How do I make the digital connection?
Connect your chosen cable from the S/PDIF Coaxial Digital Audio output on the Wadia 170iTransport to the corresponding digital input on your Digital to Analog Convertor, Digital A/V Receiver or Digital Preamp/Processor.
How do I make the analog connection?
Connect your chosen cable from the Left and Right Line Level Audio outputs on the Wadia 170iTransport to the corresponding analog input on your Television, Stereo Receiver or Other Analog Input Device. You will need to use the mode button on the remote to activate the analog outputs on the 170iTransport.
How do I make an S-Video/Composite Video connection?
Connect your chosen cable from the S-Video output on the Wadia 170iTransport to the corresponding S-Video input on your Television, A/V Receiver or Preamp Processor. For Composite Video Display output, you will need to purchase an S-Video to Composite Video Adapter cable. Please contact your local dealer for more information on this type of adapter. You will only be able to use the S-Video/Composite Video output with the iPod Video. In order to activate the S/Video output, you will need to use mode button on the remote. When you use the S-Video output on the 170iTransport, you will be limited to analog audio output.
How do I make a Component Video connection?
Connect your chosen cable from the Component Video output on the Wadia 170iTransport to the corresponding Component Video input on your Television, A/V Receiver or Preamp Processor. (The Wadia 170iTransport only acts as a high-performance pass-thru for video signals. Picture performance is limited to the quality of the material stored on the iPod. Some video adjustments may be necessary on your video display for maximum video performance).
Thus it does look as if you can connect the iTransport to any system that takes in digital and analogue inputs. The iTransport looks like a system I will want on my rack. It looks absolutely delicious !!!!!
thanks venkatcr.
hi everybody once again,
can someone recommend good DACs?
also if someone can throw some light on DACs, pricing, tips on usage and connection, it would be of great help. i don't know anything about DACs.
thanks in advance.
Vilfy,
I'm not experienced with hi-end DACs, but FWIW I have a Beresford DAC connected to a T60 via a X-Fi Xtreme Audio Notebook. I find it pretty good and was clearly surpriced by the difference it made!
Since you are using the likes of Wadia, may be a something like a Bel Canto, Benchmark DA1 and the Harmony DA9 will be an ideal choice.
All the best.
I do have one of those (well, a lot of guys around here owns it) connected to SB Duet. For my ears, sounds good!
I can offer you a Theta Data D.S.Pro prime D/A converter for 15K if interested call me on 09821214981.
Homiyar
Vilfy,
thanks everybody for your informative posts.
unleash me,
can you please tell me where can i find the above brands in mumbai? any idea on their pricing
Vilfy,
I dont know the dealers of these hi-end DACs in India. But you can always write to them.
Benchmark Media Systems, Inc.
Harmony Design
Bel Canto
Sorry bro, cldn't help you out here. When ever I had chances of hearing transport/dac based systems, dint pay much interest, thinking it would be too complex for my requirments:(
I remember having a similar discussion around DACs with our fellow members Gopi and Reignofchaos. Hope they can chipin.
Anyways, all the best for your efforts!
Best Regards.
DAC (and ADC) are huge topics and would need a complete engineering course. But let us see if we can understand it in a simple way.
After the definition, I am going to add some fun by delving on two controversial topics. One is the need for an external DAC, and the second is whether the analogue form is better than the digital form.
BEGIN DEFINITION
Analog describes any fluctuating, evolving, or continually changing process. A base carrier's alternating current frequency is modified in some way, such as by amplifying the strength of the signal or varying the frequency, in order to add information to the signal. This information is then stored or broadcast.
Digital describes electronic technology that generates, stores, and processes data in terms of two states: positive and non-positive. Positive is expressed or represented by the number 1 and non-positive by the number 0. Thus, data transmitted or stored with digital technology is expressed as a string of 0's and 1's. Each of these state digits is referred to as a bit. A group of 8 bits is referred to as a byte. .
An audio signal is converted to electrical signals for storage and distribution. Because sound has notes (pitch) and volume (loudness or amplitude), it is represented by a sine wave. The pitch of a musical note is the same as its frequency. The intensity or loudness of a musical note is the same as its amplitude. The third element is the time domain that is represented in the sine wave by a cycle. The term, sine wave, originated because the modulation of the carrier wave is analogous to the fluctuations of the human voice or other sound that is being transmitted.
When you take something as simple as alphabets and numbers, they have fixed representation in digital form, mostly consisting of eight bits for alphabets and four bits for numbers. Thus the representation of alphabets and numbers is digital form is very simple. For example an 'a' is always 01100001 in its binary form.
A sound wave, represented by a sine wave, is a different thing altogether. A sine wave is continuous and has infinite number of datum, that keeps changing continuously. To represent this in digital form, you need to do what is called sampling. In sampling, you represent the sine wave over periodic intervals in a digital wave form, and then convert it back to a sine wave by interpolating the data. Sampling is usually carried out in two stages, discretization and quantization. In the discretization stage, the space of signals is partitioned into equivalence classes and quantization is carried out by replacing the signal with representative signal of the corresponding equivalence class. In the quantization stage the representative signal values are approximated by values from a finite set.
In order for a sampled analog signal to be reconstructed, the Nyquist-Shannon sampling theorem must be satisfied. This theorem states that the sampling frequency must be greater than twice the bandwidth of the signal. In practice, the sampling frequency is often significantly more than twice the required bandwidth. The most common bandwidth scenarios are: DC - BWx (baseband); and Fc +/-BWx, a frequency band centered on a carrier frequency ("direct demodulation").
An analogue to digital converter (ADC) converts analogue signals to digital signals. A digital to analog converter (DAC) is used to convert the digital signal back to analog. In general the operations of a ADC and a DAC come under the domain of Digital Signal Processing.
END DEFINITION
Now to the fun part.
Processing of pure digital form is quite simple as it consists of a finite number of elements. That is the reason why, when you save a text file in a computer, you always get the same text any number of times. The data never changes, unless you change it. Of course you can lose the data if the hard disk fails, but that is a electro-mechanical issue, and has nothing to do with the digital form of storing data. Even this has become very rare, if you follow some simple procedures. In my 25 years of working with computers, I have never, never lost one byte of data. One important point here - when reading or writing data, the head of a disk drive never touches the drive platter.
Now take a tape drive. The tape has a magnetic coating in which the data is written in the form of frequency variation. Remember magnetism is never permanent unless it has some energy driving it. All magnets lose their intensity over time.
To write and read, the head must touch the tape. In the process there is a continuous decay of the coating. Remember the need to clean the brown stain off read/write head with Isopropyl Alcohol? That is a bit of magnetic coating removed from the tape. Similarly, when you consider a turntable, the cartridge has a small needle that is scratching the disc. Again every time you play the disc, you are enlarging and deepening the pit, thereby modifying the data. .
In other words, every time you use a tape drive of a turntable, you are slowing destroying the data, or adding data in the form of noise. This can never happen in a digital format, as there is no mechanical friction of any kind.
Now to my FIRST fun point. External DACs such a the famous DAC1 from Benchmark uses AD1853, a Stereo, 24 Bit, 192 kHz, Multibit Sigma-Delta DAC. Good CD players such as those from NAD, Cambrudge Audio, Rotel etc use chips such as Burr Brown's PCM1737 which is a 24-Bit 192-kHz Sampling Advanced-Segment Audio Stereo DAC. If you look at the specs of these chips, they are very very close to each other, if not identical. Since both DAC circuitry (assuming they are both designed and built well) work on the same finite number of digital data, and send them to the same pre/power amplifier, how much difference can an external DAC make to an already excellent DAC that is inside the CD Player? If at all it does make a difference, it should be of very small magnitude, say less than 5%, to the quality of the sound.
If you read Stereophile, John Marks enthusiastically wrote about the Benchmark Media Systems DAC1 D/A processor and headphone amplifier. Comparing its sound playing CDs with that of a three-times-more-expensive Marantz SA-14 SACD player, he concluded that the DAC 1's "Red Book" performance was at least as good as that of the Marantz, being "slightly more articulate in the musical line, and slightly more detailed in spatial nuances, particularly the localization of individual images in space, and in soundstage depth."
In my mind, these are subjective terms that anybody can use positively or negatively as is required. Everything is slightly more?
Now to my SECOND fun point. An original analogue sound properly converted through a ADC to digital, cut well into a CD (or let us say as uncompressed data in an hard disk), would always provide consistent information for playback and amplification. Irrespective of how many times you use the data, the information will be the same. Assuming you use a good CD player, a good DAC, and the same pre/power amplifier after the source, the sound from the digital source should consistently be better than from an analogue source such as a Turntable.
I show below Lie Number 3 - The AntiDigital Lie - from the Ten Biggest Lies in Audio. This is written by Peter Aczel in his 26th Issue of The Audio Critic. I just quote the exact text below. I am sorry if his wordings are a little harsh.
QUOTE
2. THE ANTIDIGITAL LIE
You have heard this one often, in one form or another. To wit: Digital sound is vastly inferior to analog. Digitized audio is a like a crude newspaper photograph made up of dots. The Nyquist-Shannon sampling theorem is all wet. The 44.1 kHz sampling rate of the compact disc cannot resolve the highest audio frequencies where there are only two or three sampling points. Digital sound, even in the best cases, is hard and edgy. And so on and so forth. All of it, without exception, ignorant drivel or deliberate misrepresentation. Once again, the lie has little bearing on the mainstream, where the digital technology has gained complete acceptance; but in the byways and tributaries of the audio world, in unregenerate high-end audio salons and the listening rooms of various tweako mandarins, it remains the party line.
The most ludicrous manifestation of the antidigital fallacy is the preference for the obsolete LP over the CD. Not the analog master tape over the digital master tape, which remains a semi-respectable controversy, but the clicks, crackles and pops of the vinyl over the digital data pits' background silence, which is a perverse rejection of reality. Here are the scientific facts any second-year E.E. student can verify for you: Digital audio is bulletproof in a way analog audio never was and never can be. The 0's and l's are inherently incapable of being distorted in the signal path, unlike an analog waveform. Even a sampling rate of 44.1 kHz, the lowest used in today's high-fidelity applications, more than adequately resolves all audio frequencies. It will not cause any loss of information in the audio range not an iota, not a scintilla. The "how can two sampling points resolve 20 kHz?" argument is an untutored misinterpretation of the Nyquist-Shannon sampling theorem. (Doubters are advised to take an elementary course in digital systems.)
The reason why certain analog recordings sound better than certain digital recordings is that the engineers did a better job with microphone placement, levels, balance, and equalization, or that the recording venue was acoustically superior. Some early digital recordings were indeed hard and edgy, not because they were digital but because the engineers were still thinking analog, compensating for anticipated losses that did not exist. Today's best digital recordings are the best recordings ever made. To be fair, it must be admitted that a state-of the-art analog recording and a state-of-the-art digital recording, at this stage of their respective technologies, will probably be of comparable quality. Even so, the number of Tree-Worshiping Analog Druids is rapidly dwindling in the professional recording world. The digital way is simply the better way.
UNQUOTE
Great post venkat, educative and detailed.
Always good to have guys like you on the forum.
Added some rep points.
The theory seems convincing,
But i feel there is some magic abt the anolouge sound.
Esp since recently we compared a good jaaz Lp & the same recording on the
K2 XRCD. Though the cd sounded good but the lp def sounded much more articulate, musical & warm.
I'd also like to know if an external DAC will improve the sound in avg cd player
aka the nad's /marantz/CA etc
I am not sure I would categorize Marantz, NAD and CA as average CD players. The DAC inside these players will be as good as or even better than an external DAC, unless the DAC is made from specialised companies such as Benchmark. A
DAC1 from Benchmark is around 950$ in the US. If you are going in for a DAC such as DAC1, I would not ven been looking for a good CD player. Any simple CD transport (costing say 4 to 5K in INR), even a average DVD player with digital out, hooked to a DAC1 should take you to audio nirvana.
My point is when you spend 50 to 60K on a middle to high end CD player from NAD, CA, Rotel Cyrus etc, you may not need an external DAC.
AudioDelic - thanks a million. Appreciation coming form a resident expert is an honour indeed.
Cheers.
Is benchmark available in india?
Which other DAC's do you consider good VFM?
I am not sure I can answer either question.
Benchmark DAC seems to be available only through the Net. If nobody else comes up with a dealer name, just send a mail to [email protected] asking for dealer details in India, if any.
Most of the DACs that have received reviews are from expensive brands such as Bel Canto, Wadia, etc.
In this forum I have seen a few people use a DAC from Beresford (Home HIFI) and they seem happy with it. This is again available online and the landed prices including customs and courier seem to be around Rs.7500 for the model TC-7510
Cheers.
Crossposting from another thread after request to do so:
If I compare an ordinary DVD player (say the ordinary LG thing) with digital out connected to a DAC (Bredford) vs a good quality CDP like CA 640C, which would be preferable?
Technically, it should be very similar as the DVD player is sending digital signals and the actual conversion to analog is done by the DAC.
Thoughts??
~dich
Thoughts??
~dich
Dich:
This has already been answered. If you have a good quality DAC, all you need is an ordinary transport that can play a CD well.
A good quality CD Player such as the 640C combines the transport and the DAC is one unit. When you connect an external, you use just the transport part of the CDP. You will be able to get very similar output with this combination or even better.
Dich:
Better still use a PC with a professional sound card and lossless FLAC files.
yes that is an option, but every PC I have owned has given that slight fan noise which can be very irritation.
I was thinking of a cheap player with USB support to connect an external HD pushing data to a DAC which would drive a stereo amp.
~dich
