Wall mount speakers for HT for a 20x30ft room
anm
New Delhi, India
Room size - 20x30ft
seating - 14ft from front wall.
Application - 100% home theater.
budget - not yet decided, so open for now
I want to wall mount speakers at a height of about 7-8 ft on front walls to keep the floor space free (most probably maggies would take that space).
I hope wall mounts shall give some space between the wall and the speaker.
^ Even that would fall short of expectations. Only FS here @ 30'x20'. Amp selection to drive the selected speakers would be a greater headache.
... 2 Mumbai apartments can fit inside your living room .... :D
there shall be subwoofer(s) to support the bookshelves. The room also has stairs - so there is a 2 storey high opening at the other end of the room.
Hmm, interesting situation. The way I see it, since floorstanders are out so you cant solve this problem with brute force (big speakers). Also at higher SPL, most speakers tend to get shouty in a large room.
See if you can get a pair of horn loaded speakers - so the throw is longer. Also, plan the viewing position such that you are within 15-17 ft max. I maybe wrong though.
Option 1: Speakers on stands near your seating position with wiring under carpet.
Option 2: Ceiling hung speakers. Check out Elipson Planet M. Available from FX Entertainment, Chanakyapuri.
Horn Wall mounted --> brilliant idea! sound type may differ from rest of the system.
Give Mirage speakers a listen,their omnipolar speakers can fill big rooms with ease....at least mine....but then it also depends on yr taste n kind of SQ u re expecting in such a big room......HT - a set on Flickr
Room size - 20x30ft
Hi anm,
That's a bigggg rooooom:D
Take a look at these :THX Ultra2 Home Theater System | Klipsch :licklips:
Wall mount & ceiling mount options available.
This will satisfy even the most hardcore audiophiles & Very few comes close for movie impact.
