Wall Mount Vs speaker stand
mandeep
Mohali (Near Chandigarh)
Hello dear all,
I have recently purchased/ordered a 5.1 HTIB speaker system.:cheers:(yet to receive them).
Kindly advise which will be better installation
wall mount
or
on speaker stands
and why? (plz explain technically )
What i want to know is, which installation will provide better sound and why?
I sit against the back wall then what should be the direction of rear speakers towards my ears or towards the room.
Thanks in advance:signthankspin:
You have to provide more information about system you are planning to install. Installation preference depends on many factors: ported or non ported speakers, front or rear ported, dispersion quality etc.
These speakers can be wall mounted without any loss of quality. That will be the better mounting option as front and center speakers can be installed at ear level and can be angled slightly towards the listening position. The surround speaker placement depends on whether you have side walls to work with or Not ?
Thanks, there are no side walls, i mean there are side walls but are very far away.
