Want advice ( speakers) for denon 1908
n_sachin84
bangalore
NAMASTE TO ALL OF U,
I AM LOOKING FOR SPEAKERS FOR DENON 1908.MY USUAGE WILL BE MOVIES 40%,GAMES (pS3)30 %,MUSIC 30%.
WELL HERE IS DIFFICULTY. I AM NOT ABLE TO DECIDE TO GO FOR CHEAP 5.1 BOX SYSTEMS OR SHOULD I GO 4 WHARFDALE 9.2BOOKSHELF OR I SHOULD GO FOR MISSION M30 CINEMA OR MISSION M33I OR M34I. I AM CONFUSED .FOR MY NEED 2 FRONT WHARFDALE 9.2 WILL SERVE PURPOSE OR DO I HAVE TO INVEST IN MISSION M35I? WITHOUT INVESTING IN SUBWOOFER WILL FLOOR STAND SPEAKERS LIKE MISSION M 32 ,M33I OR M34 OR M35I WILL SERVE MY PURPOSE? BIGGEST TROUBLE OF SOURCE BUDGET CONSTRAINTS .AROUND RS 20,000-30,000.
HI ALL AUDIO GURUS PLZ SUGGEST ME WITH BETTER OPTIONS.
WAITING FOR UR SUGGESTIONS,
SHIV
Namaste Sachin. What's up with the shouting ? - even if you whisper to us your needs, we'll deliver, mate.
SHIV
Sachin,
Post your requirement clearly .
Kind of music u listen ?
Your room size / type ?
Are you looking for a complete setup (5.1) or trying to build it slowly?
So far what have you auditioned ?
I see you are posting the same in many places .... Keep this thread dedicated to your requirements and let the experts help you on what you need.....
Good Luck....
Kittu:cool:
