Want to Buy Bookshelf Speaker & Amplifier
S. Basu
Kolkata
Dear Sir,
I want to purchase New Bookshelf speaker and integrated stereo amplifier with FM tuner which I got from Yamaha R-S201. My budget is 30k and my room size is 10*12. I am from Kolkata, India. Suggest me which is my best option. Further I got a 2nd Hand Wharfedale bookshelf speakers crystal 10 just Rs. 10k and Philips fa 931 (Amplifier). Kindly provide ur opinion. If I want to but fresh system where from I get it from Kolkata.
You can go for sonodyne amp - (priced at 14K and 17K) and Sonodyne bs can cost you around 15K. So it will be within your budget of 30K. And if you can wait till Jan 26, you will get a flat 26% discount on the MRP. Sonodyne showroom is located at South city mall and Mani Square. You can have the demo there and decide.
There are other options here too...but considering your budget (30K) I think this pair will fit only.
Thanks for your rply. But I hear sonodyne sound bookshelf speaker Sonu 1501 V3 with amplifier SIA 301. Sound quality is good but bass quality is poor. If i take separate sub woofer quality not matched. if i go Boston Acoustics A 26 Bookshelf Speaker (Pair, Black Finish) with yamaha amplifier R S-201.
