Want to Connect SET TOP BOX with Projector.
balasound
India
I have a Sun DTH old STB(SN9000IR) with output of S Video, RCA and co-axial TV out. I want to connect to Dell M110 projector which has input HDMI, A/V in, Universal I/O and USB. Which cable will work fine and is it need to buy a analog to digital convertor?
With old STB, you can connect with RCA cable (Just yellow video out connector will suffice). Any local good cable is more than enough. You don't have much simpler and cheaper option.
For audio, you will need separate input system.
Thanks for reply. First I tried by connecting red rca cable on video out and 3.5 mm A/V to projector. Not successful. Then I tried with white rca cable to video out still not successful.
Note : sorry . I forget to mention. my projector do not have RCA input but have 3.5 mm A/V input.
Check the pictures of STB output and Projector input. I tried by 2 rca to 3.5mm a/v jack.
i'm planning to change SUN DTH STB with new one instead of buying convertor because RCA to HDMI convertor price higher than new STB price.
Which model is ur projector??
Also
Kindly read the manual of projector, it will surely indicate what sort of cable u need :)
Simple
The cable u putting wint work
Refet to manual pls
thanks for replay. Today i bought 3RCA to 3.5mm a/v jack. It is working fine :). 3.5mm a/v jack must be 4 division otherwise it will not get proper connection. Please refer following picture.
