Weird speaker functionality required
barcode
IN
hi everyone,
i would like a speaker set up in my dining and living room area that can be set up in a way that the music can be played in all areas simultaneously.. or just in one of the areas.
secondly, i would like a player that I can put aside in one corner and want least amount of wiring to go around my house.
what is the starting point of doing this set up. Budget isn't a constraint.
if I can extend the coverage to another room and control all this via a bluetooth device (ipad/phone) - it would be even more amazing.
if someone has a setup or another thread that discusses the same, please feel and point me to it.
also - if this thread is in the wrong area, please move it to the correct area.
thanks
you can get two sets of stereo speakers. depending on your room constraints and size, either bookshelves or floorstanders. a lot of the stereo amps come with speakers a and b output. so you can select to have on either a or b or both
