Wharfedale 10.1
on the top bar there is a search function If you type your query it will tell you where in the forum you can find the relevant discussions. A useful tip.....bass is spelt bass and not base. Good luck!
Cifrancis, On the top right hand side of this page you will see a search tab right next to log out and quick links. Type wharfedale 10.1 in that and you will get a number of threads on it, read up and you will get an idea. In case you still have some specific queries, post on the thread, the members will happily help you out.
Good luck.
i wanted to know whether Wharfedale 10.1 is good for bass or should i look for some other speaker my budget is below 15K
