what and how to buy speakers and av reciever ?
haricharan
chennai
Hi Guyz,
This is my first post out here and this happens to be the first speakers that i'm planning to buy (need you expert advice to guide me through this.)
i have a decent knowledge of speaker and have a liking to the mids and lows. After a harrowing search across the city with a tight budget of 60K.
My room size is 11 x 13. I already own a 32 inch sony bravia. Purpose is goona be tons of music and 30% of movie watching.
I started my research with run of the mill sonys (pathetic) to the unafforable MBL's. What i have zero'd in on is either klipsh RF-10 with center ,2bookshelves and a 8 inch sub with denon 1909- goes way beyond my budget - 1,13500
Adding to the confusion the dealer had a year and a half old jamo D8 series front with 3 way bass reflex, D8 center and 2 way book shelves - for 65k plus my denon amp . This interested me as the speakers performed better than klipsch and others like pardigm, modershot which i did not like. Flip side is the bass was very channelisd and defenietly requires a sub woofer. i s this a good buy ?
Please advice wether my filteration is on the correct lines, do you guys know of any cheaper delears ?
hi hari
good that you've done some research before asking questions. firstly is your budget for 60k just for speakers or for the full set up. also if youre main aim for listening is music, then dont go for the sub / centre etc etc. just a pure 2 channel setup will have much better SQ than going the multi speaker route.
depending on your budget, i would suggest
speakers
monitor audio bronze or silver series
kef iq series (comparing to the bronze series)
when auditioning speakers, dont worry about whether they're floorstanders or bookshelves. choose depending on what sounds better to you. if you like your lows take cd's along which will showcase what the speaker can do when its pushed deep down.
amp
either the nad / cambridge / marantz as an amp, in no particular order - they're pretty much in the same bracket - just that each of them have their own characteristics and its about suiting your personal preferences. the amps im suggesting are stereo amplifiers
an entry level cdp - again nad / cambridge / marantz
budget:50,000(can rise abt 20%)
music:movies=70%:30%
music:mostly rAhman kind of music ,
dil chahta hai,
hotel california,eric clapton
slow rock,
western classical,
hip hop
movies:italian job(backround score is very good),suspense movies,stage programs
(musical which takes palce in big stadiums)
room:(length,breadth,height)(18,12,10)
which dvd player?
which amplifier?
suggest any other than wharfedale diamond 9 series if u like?
as i've decided to go for wharfedale speakers for it's value for money and quality
after getting it's review for diamond 9 series(and it's value for money)
preference:
1.crystal clear sound without distortion in low ,mid,high ...range
2.with good surround and good bassfor hip hop
3. good service avilable in delhi in case there is any need of that
4. hassle free system
5.for long run(durable)
6. hdmi feature is not required but should b 7.1
7.i want to pay for quality not for brand value(should b value for
money)
8.want best combination of dvdplayer+avr+speakers
9. very high decibels r not my choice which can even disturb ppl very
far frm my home
please comment on best working avr wid wharfedale speakers diamond 9 series.
which 1 of them (avr,speakers,dvd player)can b bought frm grey market which really
don't require much service)
budget:50,000(can rise abt 20%) for avr ,speakers(like 5.1)
dil chahta hai,
slow rock,
western classical,
hip hop
which dvd player?
which amplifier?
preference:
money)
far frm my home
which 1 of them (avr,speakers,dvd player)can b bought frm grey market which really don't require much service)
look at the kef iq speakers and the monitor audio bronze series. since youre set up is going to be two channel look at a stereo amp - nad / cambridge / marantz
