What is Dynamic Range and why it matters?
Dynamic range is something that I prefer to be less than 10db, most of my music is between 3-9db. Some people prefer more but I don't find it musical. In my player I enable volume leveling so that music is of similar volume. I think I prefer a dynamic range of 3-6db. A dynamic range of 50db would be very hard to realize in a practical perceptible way. IMO it won't be musical.
True. I have to crank up the volume for the few excellent recordings that I have on CD and DSD recordings.
This is the prime reason why many find vinyl better than digital. It is not because vinyl is a better medium. The dynamic range of a direct-cut vinyl record may surpass 70 dB. Analog studio master tapes can have a dynamic range of up to 77 dB. An LP made out of perfect diamond has an atomic feature size of about 0.5 nanometer, which, with a groove size of 8 micron, yields a theoretical dynamic range of 110 dB. An LP made out of perfect vinyl LP would have a theoretical dynamic range of 70 dB.
CD can give a much higher dynamic range than LP, but in practice what you get is recordings with compressed dynamic range and this is one of the prime reaons why digital music have got a bad rep. In fact many wrote about this practice by the recording industry
With the pop music business having become very competitive, a myth arose among producers and record companies that the way to get one's record to stand out (in the competition for airplay) was to make it as loud as possible. Since the loudness of a LP or single is subject to a the physical limitations of the medium, the way to make a record, especially a 45 rpm single, louder was to compress it heavily, much as commercial radio stations do to sound loud on the air. Some rock may not sound bad heavily compressed -- the Beatles and their producer George Martin were able to use compression artistically.
Some research too has gone into this loudness war started by the recorded industry
Curious to know why one would like low DR music. Can you please explain?
Why would a singer for example, not whisper at 30 dB lower than when they reach crescendo in the same song? And wouldn’t it sound unnatural if that range is compressed down to 6 dB instead? It can’t be much fun listening if a light brushing sounds as loud as boom of the kettledrum?
In fact, most of the rich/complex music, such as Jazz and Classical has high dynamic range (played as well as recorded). Must be for a good reason.
I find it to be constant and smooth when the dynamic range is low. With high dynamic range it is distracting and is not soothing, with very high dynamic range if the passage is too low then it almost feels like no music is playing, and if it is too high (especially suddenly) then it is a jolt.
I don't know why a singer would not whisper 30db lower (these things don't matter to me) but I think that based on your post you value accuracy, not necessarily to the signal but to real life music as you perceive it. I value tone above all else.
Interesting, I don't find jazz/Classical to be rich or complex. They may have high dynamic range on some recordings but I don't listen to these genres. I think the reason is simple, they make what sells. I primarily listen to Rock,Metal and Electronic. A bit of Pop. Maybe that will help you understand the preference for low dynamic range as these genres often have low dynamic range and many people look down on these genres for their low dynamic range, especially those who listen to things like jazz and classical.
“They make what sells” seems to be a good sum of the state of the audio recording industry. The article also menations low Dynamo range and highly compressed formats are in use by the vast majority of people who listen to music. What the majority accepts is what is sold, provided and broadcast and consumed. Nothing wrong in that at all, but it may not be as satisfying to some discerning music lovers who prefer higher dynamic range and lossless data for their carefully set up audio system. The latter is a niche market for a tiny minority.
As you have alluded it’s a personal preference and choice.
I recall days past when I was oblivious to these issues and possibilities, and just enjoyed the music through whatever source available.
They make what sells applies to pretty much everything. Most people listen to low dynamic range because that is what they make, and they make this because that is what sells, and it sells because that is what people like. While it may not be satisfying to some I feel the use of the word discerning is misguided, picky for no reason is more like it. Most people can not hear the difference between lossless and lossy. Most of the time lossless just seems to have more HF, hence more detail and clarity, that doesn't mean it's better.
Being oblivious and ignoring things that don't matter are seperate. I know but ignore this. I care about music I like, I don't seek out high or low dynamic range, nor do I seek out lossy or lossless. I listen to whatever I get as long as the music is to my taste.
Thanks. So what you are saying is that you like certain genres and they are typically sung/recorded with lower dynamic range and hence you are used to lower DR. That’s understandable.
It’s not clear yet though why high DR would sound less musical. Unless one’s system/ears are not able to resolve/decipher the less dynamic parts (and hence miss out on the musical information in it) while also undistorting/tolerating the excitement of the more dynamic parts. Age-related listening sensitivity could also be a contributor to this, I’d imagine. (None of this to be taken as a personal comment please, we are just theorising here).
I was not referring to generes.
I have heard some well recorded tracks played back both compressed (mp3 files) and FLAC and preferred the latter.
In my home audio set up this matters and I try to choose uncompressed formats, while driving and listening to Spotify it matters not so much.
To confound matters I discovered that some poorly recorded material sounded bad to me even with lossless files when I had a set up that was very revealing of details.
As usual a technically sound and educative post from you ✌️ Really loved going through this and you hit the Vinyl vs Cd debate on the Ji spot :D ie its about the mastering and not about the format.
Dynamic range, for some music is needed to truly hear what it was meant for ie if the system is not able to clearly articulate the softest sound and the deepest/Loudest one in the same way , you are missing out on something . if you like blues guitar then Tin Pan Alley is something which you get that feeling of Smoke and Whiskey perhaps due to the Dynamics. Incidentally the CD pressings of this ( not sure of new ones) were also very good. i had one which i seem to have misplaced but have the Vinyl which is pretty awesome.
So true..its maybe less of what people like but more about How people listen to, The majority have pretty limiting earbuds or. bluetooth speakers which are anyway limited and the only way to make it sound good in it is to compress and limit the dynamic range.
And that may be the reason why we debate CD vs vinyl but its not really the format but the "market" this was pressed for.
Yeah, it’s sad that the CD masterings have traditionally compressed the DR - possibly to suit the limitations of the early CD players/DACs. And with streaming catching on, where most play compressed music anyway, it just stayed that way (with notable exceptions). However, now that streaming (the most popular consumption form today) is moving towards lossless and even hi-Res, which means the consumers have gear for it, perhaps digital mastering would revert back to full dynamic range recordings.
By the way Manavendra, what would be the DR limitation for digital recording on hard disk? Would there be (theoretically or practically) any? I believe a DR of 30-40 dB is good, 50 would be ideal. Anything beyond that would be difficult to listen without noise cancelling earbuds/headphones. The ambient decibel levels are usually 45db (worse in cities like ours), so, a recording with 50db DR would still approach 100 dB loudness level in order to make the softest portions audible/discernible. We don’t really need a higher DR than what CD/LP allowed.
My bad. I quoted your reply mistakenly while I was replying to @Decadent_Spectre’s reply below yours.
One of the biggest example of this is in our own backyard. Vinyl recordings of old Hindi songs are way better than the CD mastered ones. If you do a spectral analysis of wav and mp3 files of songs from (40s to 80s) from Saregama, you will find the wav versions indistiguishable from the mp3 versions. The only thng I can fathom is that they made the mp3 files by compressing the dynamic range and then made the wav files from the mp3 version. They never had good archieval facility. There was a major fire in the HMV godown in Calcutta where they lost pleny of those masters. Another reason is that the indian cinema industry never invested in good recording studios. It was only after people like Bappi Lahir who made their own studios, we started getting good recordings. Later A.R Rahman also invested in making his own recording studio. India has forever lost tons of music from that period that could have been recorded better.
There is also another reason that I came across which stated why the industry didn't have good recording studios in that period. We had a finance minister, Tiruvellore Thattai Krishnamachari (TTK). I think this is the same guy who founded the TTK industries. During one if his tenure as a finance minister he made it very difficult to import equipment that went into the cinema industry. During the 50s the indian cinema become the world's 2nd largest cinema industry. Lot of imports of equipment happened by this industry and there was an embargo to force the industry to use "Swadeshi" equipments. This is something I came across and I will try to find that article. The domestic equipments weren't of good quality and the industry was forced to use that. I suspect the dynamic range suffered because of that and this unique case with India was not due to "Loudness war" that the west went through.
I suspect folks in noise polluted cities just cannot listen to recordings with high DR. At normal listening levels, the quiet passages cannot be heard. It also probably depends on how many years a ear has heard. Old age impacts the ability to hear the quiet passages and hence they prefer something where the quiet passaeges are raised to a level where they can hear it.
CD's can easily give a DR > 90. There is no point in having High Dynamic range unless we can record it. Microphones too have a limitation. The broadcast standard of 24bit at 48kHz extends the dynamic range to just short of 150dB. Remember that you don't require anything more than 140 dB of DR because that is what a young ear can hear.
Dynamics are one of the essential ingredients — along with things like melody, harmony and rhythm — that make music pleasurable and compelling to listen to. A song that provides noticeable variations in level is almost always more engaging than one that stays pretty much the same from start to finish.
Dynamic range:
  • Human hearing has a dynamic range of about 140 dB.
  • Condenser microphones have a dynamic range of about 125 dB.
  • CD-quality sound (16 bit) has a theoretical dynamic range of 96 dB.
  • Hi-Res Audio at 24 and 32 bits, has a theoretical dynamic range of 144 and 192 dB, respectively.
For practical purposes 16 bit is enough for most listening environments. If you are staying in a quiet village or if you have your own anechoic chamber you can benefit from 24 bit HiRes recordings.
Maybe true on the first point..but not about 2. most of the music compressed is the newer gen music. On the 2nd Considering I am 50+ and barely hear above 13Khz...i can make out the difference quite well ;) ..and my ears are not really that great.
Yes thats true. one of my friends had sold them the memory devices and servers for the same :) he regrets it now. Their Wav sounds hollow for the same reason..you cannot upsample from mp3 to wave and expect it to sound different !
ON indian cinema the recordings seem to be more midrange focussed on Vinyl for broadcast purposes and not for playing via records on hifi systems. but considering their digital versions are even worse, thats all we are left with.
If you do remember a movie "Yuvraj" music based on Beethovens 5th..wonderful music and horribly recorded. What went bad there I wonder.
I think at that same time the minister of Broadcasting banned film music from AIR s to only classical music and "Radio Ceylon" was formed with Sri lanka and the Binaca Geetmala started for popular music as there was a pent up demand !
Yes. And the popularity of Radio Ceylon then indicates how much the law makers were out of sync with the populace on the matter. I’m told even the harmonium as an instrument was banned from AIR at one point.
We are going off topic, but I feel little bit of history is ok, else mods can move this somewhere else. Harmonum came from the west. Because of this and the swadeshi movement there was an anti-harmonium brigade that got formed. All India Radio (which, at one time, had the monopoly over commercial radio broadcasting in India) then banned the instrument from its airwaves from 1940 to 1971. It now allows the broadcast of orchestral music of which harmoniums form a part, but solo harmonium recitals are still prohibited.
Here is another intesting article on the harmonium
Yes, it’s off topic. But the banning wasn’t on the grounds of it not being an indigenous instrument (even violin isn’t, for that matter), but because of its limitations - especially in playing the microtones (Shrutis) and ornamentation (eg gamak) so integral to Indian classical (and classically derived) music. This limitation is easy to understand in comparison with the Sarangi - the common substitute for harmonium (or vice versa, in fact).
Even so, one wonders what business does government have in enforcing this? Just leave it to the musicians - they’d use what they find appropriate. So, while the classical gharanas from the northern states generally use sarangi for accompaniment, gharanas with large musician base in MH/Karnataka such as Jaipur-Atrauli or Kirana still prefer the harmonium.
Also, necessity is the mother of innovation. We’ve seen modifications done by creatively minded musicians to western instruments like the slide guitar, saxophone, even harmonium, to adapt them to Indian music.
High dynamic range music also needs amps and speakers that are cable of handling the 10-15db of the dynamic range...
Here is a video which explains it's very nicely
Actually something that is being glossed over here is the amp/speaker requirement to produce a dynamic range of say 70db. If you listened to music with the base being 60db then you need 130db capable speakers and amps. I don't think anyone will like this. Most music in practice will rarely have dynamic range of over 15-18db. Often you might find this at live amplified concerts. If you talk of actual music then if you ignore the "silence" then you won't find 70db of dynamic range I reckon. Of course modern "mobile" audio systems from small speakers to earphones will have a hard time producing such range. The quieter parts will also get drowned out if your peak is say 110db and the low part is 40db. Please remember that for each 3db gain you need doubling of power. I think most people with Vinyl or other media with high dynamic range might be surprised to see the actual dynamic range, even more surprised to see the actual reproduced dynamic range.
Apologies I did not know you meant to quote me. I will reply here -
I am used to the lower dynamic range but I also like/prefer it. I think it is more musical as I have already explained above. Most music today does have it and it is because people prefer it. Possibly like myself people want constant music rather than peaks. Dynamic range is also something to do with taste, there isn't any standard other than those that preach one under the guise of their own preference, it is upto the individual what they prefer.
