what receiver to reuse speakers
dyna
bangalore
I have 5 speakers from my old DVD Htib LG FFH-DV55 (I bought in 2003). The home theater system is pretty much useless now.
Now, I am planning to buy a cheap 5.1 receiver (say denon 1311 or any other suggestions?) with a price point less than 20K.
So I am wondering whether I can use the speakers from my LG system. I know the LG speaker quality is not that great. But I am ok, if it is somewhat decent. Later I can upgrade to good speakers.
So, how do I find if my LG speakers are compatible with denon 1311.
This is the spec I found on the speakers:
front (3 way, 3 speakers) - (6ohms: rated 75W, Max 150W)
center and rear (6ohms, rated 30W, Max 60W)
Is it better to have denon 1311 + above speakers or it is better to have an onkyo 3300 ?
Thanks for your suggestions.
dyna.
