What to buy?? 5.1.2 setup please help
Sai meeniga
Guntur
I have budget of 1.7L
I am looking for entry level 5.1.2 setup
i am so confused about what to take
i had multiple option but confused to finalize one
Denon x1700h is fixed
i am so confused about speakers
i had these options
1.polk t series 5.0 package
2.taga 607 5.0
3.yamaha f71 , NS 444c and ns333
4.elac cinema 12
5.Mission mx 3 5.0 + ms 200 sub
6.Wharfedale crystal 4 5.0 (over budget)
for subs
1.Yamaha ns 300
2. taga harmony tsw 212se
3.jbl a100
for atoms
1. taga tcw 190 (basic)
2.jbl arena 61c
i had these options
2.taga 607 5.0
4.elac cinema 12
for subs
1.Yamaha ns 300
3.jbl a100
for atoms
2.jbl arena 61c
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
I think Polks makes sense. Yamaha too. ELAC Cinema 12 comes with a 12 inch sub so that should be quite good.
For atmos any speaker which can deliver maximum frequencies between 20hz and 20khz will be good. Depends on the placement and your budget,
Audition before purchase or read reviews / youtube videos to get first hand user experience.
