Which Bookshelf Speaker
navinsinha
Presently, I am using Acoustic Research (AR18) bookshelf speakers. My amp is a combo of SAE XXX pre and SAE XXXI Power amp. I want to upgrade my speakers now. I am contemplating Wharfedale 10.1 or 10.2 or Diamond 220. I want our FMs to kindly suggest if I am right or are there some better alternatives? My budget is around Rs. 25,000/-.
you should definitely give GR research speaker a try.excellent allround speakers and great vfm imho.
cheers!!
You could look at pre owned if you are comfortable with that. Check out hifiads.com also which is a sister site
Thanks Bro,
But looks like GR Research are located in USA. How to manage the whole thing?
You can try posting in the wanted section for GR REsearch speaker kits. Maybe someone from the group-buy never put them together, or import the kit from the U.S and put them together locally.
I am considering this myself too, but before you do all that, see if you can demo them.
