Which bookshelf speakers
Percy123
Confused between PSB imagine b and KEF LS50. Which one would you recommend between the two? Please don't confuse further by quoting something else :)
Kef is about 20k more expensive but if it's better am ok paying.
They are all good, try to audition them at a member's place or at a dealer's and pick the one that your ears like the most.
MaSh
Prob is that these are kept by two separate dealers with two very different room size/acoustics... Hence difficult to compare
Well in India thats the best we can get. Its all about being able to get an idea of what the speaker can do. Carry your own content and audition.
MaSh
Most book shelf would have a tough time producing low end.. So consider PSB imagine b and adding a subwoofer for 20K difference..
Audition both brands with your music / movie clip...then check the specs and see which has a good sensitivity...also check which brand offers more frequencies between the 20hz - 20khz spectrum......the more closer to 20hz..better bass and punch...and the more close to 20khz...better crisp highs and clarity.....lastly see the size difference, ease of placement at your home etc.....then take a call....
