Which mobile I buy for best audio quality for my contact my av receiver via fiio BTA 30 pro dac
Vinayak@
Talegaon dabhade maval 410507
Which mobile I buy for best audio via BT codec quality ? I will connect that mobile my Yamaha Rx-n600 av receiver via fiio BTA 30 pro dac.... I watching apple 15 plus plz suggest
Here, your DAC will do the decoding, so your phone won't matter. It just has to stream to the DAC via BT or a wired connection.
ALmost all phones support aptxHD LDAC on bluetooth. So check that out. When you connect phone via usb to FiiO, you need to install USB Audio Pro app for best output.
I am on the Apple ecosystem, but for your requirement I won’t suggest iPhone. Your DAC has aptX and LDAC codecs, neither of which Apple gadgets have. So you’d be only transmitting SBC or at best AAC. Get an Android phone with aptX HD or better still, LDAC codec support.
But a more basic question. Shouldn’t the choice of a mobile phone depend on many other factors besides its BT usage for streaming? Unless you are looking at using the mobile phone exclusively for music streaming purpose. In that case, why not explore much cheaper Android based DAPs which are focused on music play, like FiiO or HiBy? Thereby you can also use it as a portable music player.
