Which oen should I buy Logitech X-540 or Panasonic Home Theater SC-PT22 ?
diliplp
india
Logitech X-540 vs Panasonic Home Theater SC-PT22
I want good 5.1 PC speakers, X-540 got very good reviews as we all know
But Panasonic SC-PT22 is 5.1 Home Theater sysem with 330W RMS output, where logitech has 140W RMS
I know RMS is not only important, but its more than double at same price.
X-540 I am getting at 6k from ebay global buy ( not getting it in india, as discontinued, don't like successor model)
Panasonic one also I am getting under 6k. though DVD player will not be used as I will use my PC as source, always.
I will watch mostly HD movies, will use it with PC only.
Please advise guys.
Also if you can suggest better 5.1 Speaker system, max budget is 8k.
Re: Which one should I buy Logitech X-540 or Panasonic Home Theater SC-PT22 ?
Experts, your advise needed, if none on them then any good PC Speakers up to 9k ?
