WHich Sub - Klipsch SW-450 or SW- 110
Flash
Dubai/Bombay/Pune
Which sub would you recommend
The Klipsch SW-450 or SW-110
Both seem to be evenly matched
the Klipsch SW-450 has a Class D amp
and the Sw-110 has a BASH amp
thats the only difference i can see.
Well i was not aware of the 110, but i have the SW 450 and it rocks the whole house @ 40 % vol.
I see a lot of difference between them from the website:
SW 450:
AMPLIFIER: Class D
AMPLIFIER POWER: FTC Rated Power: 200 watts continuous @ 1% THD, Dynamic Power: 450 watts
BUILT FROM: 2009
DEPTH: 19.5 (49.5cm)
DRIVE COMPONENTS: 10" (25.4cm) high excursion, fiber-composite cone, down-firing woofer
ENCLOSURE TYPE: Bass-reflex via rear-firing port
EXPORT VOLTAGE: 220 VAC 50/60Hz
FEATURES: Volume, Lowpass, Phase, Auto Power
FINISHES: Black vinyl
FREQUENCY RESPONSE: 28-120Hz +/-3dB
HEIGHT: 17 (43.2cm)
INPUTS: L/R line-level RCA jacks, L/R high level speaker binding posts
MAXIMUM ACOUSTIC OUTPUT: 115dB @ 30Hz 1/8 space, 1m
OUTPUTS: N/A
PHASE: Switchable 0-180 degrees
VOLTAGE: 110/120 VAC 60Hz
WEIGHT: 35.5 lbs. (16.1kg)
WIDTH: 14 (35.6cm)
SW 110:
AMPLIFIER: BASH Digital Hybrid
AMPLIFIER POWER: FTC Rated Power: 200 watts continuous @ <2% THD / Dynamic Power*: 450 watts
BUILT FROM: 2010
DEPTH: 17" (43.2cm)
DRIVE COMPONENTS: 10" (25.4cm) Active non-resonant Woven Fiberglass driver
ENCLOSURE TYPE: Bass-reflex via front-firing slot port
EXPORT VOLTAGE: NA, EU, CCC
FINISHES: Black pica
FREQUENCY RESPONSE: 28Hz-120Hz 3dB
HEIGHT: 14" (35.6cm)
INPUTS: L/R Line-level RCA jacks, L/R High-level speaker binding posts, WA port
MAX ACOUSTIC OUTPUT: 113dB @ 30Hz
OUTPUTS: None
SENSITIVITY: 104dB @ 40Hz
VOLTAGE: 100-120V / 220-240V~50/60Hz 2A (Auto-voltage switching) with 1 Watt standby
WEIGHT: 35lbs (15.9kg)
WIDTH: 12.5" (31.8cm)
The 110 has thd @ 2%, i really dont know what it means in real world, but just trying to compare, also the dimensions and the driver of 110 are different. Sw 450 has better db levels 115. Check if there is any price difference, go for the one which is costlier, which may be better.
Class D amps are more efficient than BASH amps though I am not sure what a BASH Hybrid is. Here efficiency means that a large %age of the output will not be lost to heat when the amp is at work. Typically Class D amps run at 85% or higher efficiency. So a 400 watts will give you about 340 watts peak power. BASH generally are about 60-70% efficient. In other words, BASH amps require more power to produce the same output as a class D amp.
Yes, if some knos the current pricing for the SW-45, SW110 and the SW112, please post.
Any one aware as to where to audition these babies in Bangalore?
outta curiosity...why wud you want to consider those, when you can afford these
HSU STF2
HSU VTF1
have to ship through borderlinx...comes to 32K & 37K respectively.
you also have the SVS SB10 NSD available for 36K in India...free shipping.
ShAQ,
Dude we have spoken about the HSU before .
However do to the really hgh cost of shipping i have decided against going in for it .
I have also heard that HSU has gone down in quality and there has been several complaints about SUbs dying out.
This could or could not be true.
But dont want to risk it with hard earned money
I recently got hold of the SystemAudio Se200 which retails in India for about 90k
I got it from a Hifiian. He was nice enough to ship it to me for an audition in my room setup.
the deal is if it does not meet my expectations I ship it back to him. I still have to run it through its paces.
However if it does meet my expectations/requirements i pay him for it .:)
:mad: Thats way too high , Infact thecoolestone was quoted 26.5 for the SW450 in Bombay i guess not more than 2-3 months ago
First I was quoted by cinebels guy (srikanth) 28800/- later some praveen picked up the phone and said no it is 31000/-:mad:.
