Which sub woofer?
LIZARDKING
Bombay
which subwoofer upto 80k should i go for, a def tech super cube or velodyne or any other which is better than both the above choices?:sos:
might be able to give you better options if you could share
-Is it for Music or HT
-What are the speakers which go with it
-Your amplification/pre amplification
-Room size
from your current choices Deftech is really good for HT..if you can swing an SVS Cylinder, nothing like it.
You would rather wait for SVS which is coming to India by end of this month or early next month.
