Thanks for the detailed feedback, did u try streaming 720p/1080p movies from NAS?
Awesome, thanks for the detailed test. So streaming my blu ray rip from NAS to my PCH via wireless N is just going to be a pipe dream for me My G router is able to start the streaming for the blu rip and i was really surprised that it was even able to stream a single frame but it just hangs after that. But did streamed numerous 720p movies up to 6 GB without any issues whatsoever. So finally all but given up, instead planning to invest on a USB 1 TB HDD for my PCH...
Yes that was the next experiment, upto 12-13GB movies streamed fine. However beyond that for 20+GB files the playback started to stutter. One improvement was that for the 35GB 2012 I had and the 45GB avatar the ASUS OPlay used to get stuck completely earlier but at least that was not proceeding and at times frames were getting stuck after that 3 seconds it played fine and went on like this.
Another thing I noticed and was reading mistakenly (my bad knowledge) was the speed in KBps that was being displayed by OPlay before opening a file. When reading a 35GB file of 90 mins duration I was guessing that speed should be 25GB divided by 90x60 seconds which is around 7 Mbps, however the same file was getting stuck when the speed shown by OPlay was 10Mbps+.
Then I realized that read speed of a video file (oPlay was displaying) is different than bitrate of the video which probably even if the OPlay was reading well was failing to either decode and play at the same time. Surprisingly though the same 35 GB file is played very well by the same OPlay when connected via USB, probably it reads ahead and buffers.
I found my PS3 to be doing better in this regard although it stuttered but at bigger intervals than the OPlay. Although I am not sure how much of this is due to processing power of the the player so my next pending experiment is to connect a laptop (Core i3, 2GB RAM) via wore to the same bridge and open the same file using VLC and see if there is any improvement, will try this by this weekend since that is my wife's laptop and she is away in this week.
Another positive thing I learnt is that the PS3 can at read 4+ GB files if the files are streamed by a network UPnP service, earlier although this sciope was there I never tried since PS3 with its built in Wifi-G connection many a time used to stutter on 2+GB files.
I will also try out a plain file copy test this weekend and inform what read speed I am getting.
However frankly I was not at all hoping to stream those 35+GB files using this bridge. My main intent was to increase the internet throuput of PS3, internet capability to Viera TV (youtube streaming is flawless) and of course improving the link speed of my OPlay and all this by bypassing the normal 2.4 GHz band and utilizing the 5GHz band. In will continue using the USB drive for big file sizes.
Lately though I have realized one important thing after I flashed my WRT610N with DD-WRT firmware. The DAP1522 Bridge is a 150mbps single stream wifin N bridge but my linksys 610N supports 2x150mbps or 300mbps in the 40MHz band over 2.4 / 5 GHz. So somewhat my DAP1522 is a bottleneck around here. Now I am looking to import a refurbished E2000 within less than 3K INR and see if I get better throughput over 300mbps connection. Btw after flasing my WRT610N with DD-WRT I have been able to make it transmit two 2.4GHZ signals as compared to one dedicated 5GHz in stock firmware thereby getting better effective range
Saikat nice try but I have more or less given up the dream of wireless 1080p streaming. I have an Airtel Broadband Wif G Router and also a Dlink DIR 655 router.
Here is my plan :-
My Airtel wifi g router will serve all my cellphones, laptops , desktops etc. I will then be using a powerline adapter to connect my dir 655 to my airtel g router only for Internet. The Dir 655 will work on N Only 2.4GHZ-40HZ mode which will serve my Smart TV and if possible a NAS (connected to my DIR 655 using Ethernet 1GBPS cable) . Do you think this setup will work for 1080p streaming ( File Sizes varying from 2 to 16GB including 3D) ?
I don't have a NAS currently and I am using a Laptop connected to my DIR 655 with 1GBPS cable for all my speed tests ! I will buy a NAS only and only if the streaming tests work ! Otherwise I will invest the same money in a media player like HIMedia/Prodigy and connect it via hdmi to my TV's.
If I understand your intended setup correctly then it is like below
Main Setup: [Internet] ? connected via PSTN Line ? [Airtel G Router] ? connected via Powerline adapters ? [DIR 655]
Now there are two plans from your side
A. [DIR 655] ? Ethernet 1Gbps cable ? [Laptop (or NAS in future)]
B. [DIR 655] ? Wifi N ? [Smart TV via wifi Adapter]
C. [DIR 655] ? 1 Gbps Ethernet wire ? [Media Player] ? via HDMI ? [Smart TV]
In this case a couple of points you must check before proceeding or spending any money
1. You Main Setup is okay, however if powerline adapters are costly you may think of cat6 cabling connection.
2. If the length of the Gbps wire is more than 10-20 feet better ensure that it is good quality cat 6 cable since recently I bought 50 m cat6 roll from ebay but that failed to work at gbps beyond 10 feet length. Better purchase from any local network shop and ask them to ensure gbps speed at your desired distance. This problem is however not there on factory crimped cat6 patch cables of lower length. Gbps speed is MUST for 10 15 GB + files.
3. Setup A is OK but it is limited to the disk transfer speed of your HDD (be it internal or USB). And most of the ready-made NAS solutions available in market gives you at max 20mbps real transfer speed but if you setup one for your own (see sam9s guide of NAS on this forum) he got upto 75 mbps. Although 20mbps is more than enough for a single HD streaming but not suitable if multiple HD content streaming is required (like one on your bedroom TV / laptop and another on your smart TV)
4. For Setup B have you already purchased the adapter, if not check whether they support 40 MHz 300mbps connection which not all N rated adapters do. These are mostly meant for bringing internet connectivity to your TV and semi HD content viewing online if available bandwidth is there. Otherwise even if your router is ready for 300 your adapter will still connect at max 150mbps.
Moreover 40MHz 300 mbps is possible only is a very ideal situation where the router and receiver are closely placed (drops over distance) and there are no other 2.4 GHz signal in the neighboring places to interfere. I have recently upgraded my router with high gain antennas (see another thread on this forum) but that is for extended range coverage only with max 5 mbps real file transfer speed. For streaming between rooms of HD content I have resorted to dedicated LAN cabling at Gigabit speeds between NAS/Router and HTPC.
5. Setup C is more promising (if your laptop has no HDMI out) since your TV usually do not have gigabit lan ports. However you must ensure that your Media Player support Gigabit Lan ports.
I have a Belkin simultaneous dual band n600 router as well a Belkin dual band n600 extender. Can I stream 1080p over WiFi?
My situation is that my n600 router is connected to dsl line in one room. My n600 extender is connected to media server pc in another room via lan cable. I have my home theater setup in the third room where I want to stream 1080p. I was thinking of buying another n600 extender to add to my home theater setup.
But looking up at your replies it seems that this will not do. Maybe powerline adapter could work?
Btw 720p rips downloaded from internet works fine.
