wireless rear speakers
shredder
India
I'm planning to go in for one of them home theatre systems with wireless ready (rear) speakers. So my question is: what is the cost of the wireless router (or whatever it is called)?
Is the sound quality through wireless good? Or is there interference, crackling, etc??
well....wireless speakers have a long way to go in audio. So dump the idea and go wired.
To achieve this one needs to wirelessely transmit the audio channel signal before amplification. And the speakers should have amplifiers in them. The back speakers will be wired at least to power outlets.
there are many that exist...profx who deals with kef and pold mentioned about having or getting them. But this still has a long way to go in terms of technology. There is so few discussion on this topic...obviously it is because it is far from being used in the HiFi industry. For this technology to even be comparable the speakers would require highly expensive power amps like ones found on receivers. and these need to be wired to electrical outlets
Highly not recommended....check these out
wireless surround speakers | AVForums.com - UK Online
Can I get 5.1 surround with wireless FRONT speakers? | AVForums.com - UK Online
http://forums.audioholics.com/forums/showthread.php?t=65800
http://www.highdefforum.com/speakers-surround-sound/112479-good-wireless-speakers.html
http://www.highdefforum.com/speakers-surround-sound/128024-wireless-rear-speakers.html
again my advise... If you are willing to compromise on SQ then jump for it. If you are buying something like LG...Bose...Samsung...and so on dont worry the SQ is already compromised so u shdnt worry much as u probably wont notice it anyways ;). If you are particular of SQ, then dont even think of this!
There is also a Successful 5.1 Active Wireless speaker system called Violet 3D and its an Indian product from a Bangalore based company called Snap Networks. You can also use this system in 2.0 configuration for your wireless surround solution. To know more about the product visit :: Violet ::
