Wiring 2 amps, class D & A/B
MaBoii
Ontario, Canada
Greetings,
I'm currently running 2 12"s off of a Monoblock Boss ar1500 amp,
i had wired both subs ( rockford fosgate hx2's ) parallel for less resistance and more thump, even put in fibreglass in the enclosure and all that..
now I'm looking to buy another amp, the Boss r6002 1200 watt amp, which is a class AB with 2 channels..
i was wondering if it would be ideal to hook up the ar1500 to 1 sub and the r6002 to the other? would the amps work well even though they're different types?
also, would it be better to hook up the r6002 to my speakers rather than the subs?
Just looking for opinions and suggestions, anything would help. thanks
Either get 2 identical amps to power identical subs or sophisticated way will be get some branded monoblock to power both subs. The difference will be amazing & u Will never look back at boss & all! Good luck bro. Don't screw those nice subs by cheap amps!
