nitinkgarg
I bought Yamaha RX-V667 and Harman Kardon Speaker from USA. Now I need to buy the transformer to use those in India.
Could someone suggest what should be the rating of the transformer to connect these 2 things.
Receiver says 400 W input and Sub Woofer says 200 W input - so total 600W.
Is 1 KVA transformer sufficient for this?
Also do I have to buy a isolated transformer - or auto will also work? The shopkeeper said isolated transformer produces a lot of heat if not used for maximum capacity?
Thanks!
Nitin
Thanks!
Nitin
