Yamaha WXA 50
Manoj Nair
Can a Yamaha WXA 50 be used as a purely streaming device when connected to a separate Pre Power separate system
Manoj
Manoj
Just Buy a WiiM Pro Plus if you only want streaming and you are done. WXA 50 just for streaming is not a wise choice. If you want to spend extra look at the offerings from EVERSOLO Or BLUESOUND.
