Hi Guys,
Im planning to build a 15" sub in a low budget.
But the interesting point here is its design idea.
Idea credit goes to our @yogibear ....Thanks a lot for so many inputs so far ..!!!
@diyaudio suggested the driver, and gave many inputs as well. Thanks a lot for that too ....
As you can see from the picture, the front of the enclosure is just left open, and the driver is mounted on the rear wall of the enclosure.
Literally, the driver is outside the box. It may feel odd in the beginning, but gradually I felt more and more interested to try it out.
It may be called something like "horn loaded dipole bass " as per yogibear
Only concern is that it is a fairly large box for my room.
One of the requirements is that the Driver having more than 0.5 Qts would be best suitable for this kind of design.
I searched as much as I can, but high Qts drivers are not found easily, and that too in a budget.
I saw Ahuja drivers, but didn't have the confidence since their Xmax is low (2 to 3mm)
Later I learned that along with Xmax, other parameters are also significant.
Any way, I ordered a 15" Ahuja driver with Qts 0.54 and Xmax 3.5mm
Today I got the MDF cut, but I have to wait for the driver to arrive.
Eager to build it as soon as possible .... I will keep updating the progress...
Naveen
Naveen
