I'm looking for speakers around the size of bookshelf and under 10kBudget?
Size restrictions?
Much better if you gave more details.
I auditioned couple of soundbars but I didn't like the sound from them. Vocals were muffled while watching Movies and Series. Background music overshadowed the vocals. I had to pump up the volume to over 50-60% to actually able to hear the dialogs clearly. Not very impressive soundstage to be honest.If you want simple and easy setup go with soundbars
Bose soundbar is good one for crisp dialogs -- its expensive , and their low end is lacking.
Also you can check any Sound bars (preferably atmos enabled , if you need it).
Another option is to look for powered monitors.
The dedicated 5.2.1 or 5.4.1 systems will be always great to have, Since they sound better + their separation is great and like move theater experience.
It's recommended to go ahead with LCR , where center channel play a major role for dialogues. If you need high bass go ahead with tower or add subwoofer to the setup.
Which powered monitors would you recommend?
whats your budget ?. You can look for JBL Studio monitors..
To run the speakers you need to buy a good amplifier or AV receiver.I'm looking for speakers around the size of bookshelf and under 10k
with 10k you may not expect much , You may check for this JBL studio monitor falls within your budget.under 10k
Check out Panasonic HT30. For 5k it's an amazing speaker system. Highs are clean and clear and the bass really strong.I'm looking for speakers around the size of bookshelf and under 10k
For this external 2.0 won't solve your problem. Background Music/Noise will always overpower dialogues and only a proper 3.1 or 5.1 system with dedicated center channel can help.while watching Movies and Series.
Sorry, no experience with 3.1 set up. Even I've been contemplating either a good soundbar with surrounds or AVR+Speaker combo. But these things definitely will cost 30K+. There are cheaper soundabars around 15K with 5.1 speaker set-up but they don't seem to be Dolby/DTS certified so not sure on channel separation.yeah I think that completely makes sense. Any good recommendation for a 3.1 setup?
Not sure why you say that. On theory, having a dedicated centre channel should be better but that is not the case always. I have a LG HTIB which i bought after listening side by side with models from Sony, philips and few more brands. I also have multiple stereo set-ups along the way. There is definitely no thumb rule, some of them provided dialogue clarity better than the 5.1. It depends on the content, source and the components themselves. At the given budget, a quality 2.1 or 2.0 options mentioned above would do better job than ultra budget 5.1 in my opinion.For this external 2.0 won't solve your problem. Background Music/Noise will always overpower dialogues and only a proper 3.1 or 5.1 system with dedicated center channel can help.
You've answered yourself.It depends on the content,
There are 3.1 channel soundbars which will be cheaper than any HTIB or component systems. But it should be little more expensive than your stated budget. Saw this one, it costs 16K, but you may get some card offers and can go below 15K.yeah I think that completely makes sense. Any good recommendation for a 3.1 setup?
