5.1 Channel using TPA3116
RSRAMESH
Hi Folks,
Thinking of building a simple 5.1 channel amp using TPA3116 (for front, center and surround) and TDA3920 ? for subwoofer.
Source - Oppo bdp103 : 5.1 Analog Output
All the Amp boards will be sourced from ALIEXPRESS/EBay
Please let me know.
Ramesh S
Is it comparable with TOPPING amplifier besides 2 and 5 channels.
I presume you are referring to TA2020 chip, I think TPA3116 is more power ful than TA2020 also got good reviews.
I am not sure about compatibility, any suggestions ideas welcome.
Please let me know.
What exactly it is that you want to know?
any other woofer amp chip i can consider ?
To the best of my knowledge, no chip is specifically built for a woofer. I may be wrong here though.
Compatibility with what exactly?
Would like to use 5.1 analog out of Oppo 103 to build a custom amp using TPA3116/TDA8920, will it work will if i buy 3 TPA3116 amp board and use one for FRONT right/left, one for SURROUND right/left and one for CENTER/SUB ?
I thought TDA8920 would be a better chip for woofer, from your answer i understand there is no amp chip available specifically for Sub Woofer, this answers my question, thank you.
I am also thinking of using TA2020 based amp in my XUV5OO, have any one tried this option in your vehicle?, any inputs suggestions please.
