5 speakers within INR 25000
lwalia
I am looking to buy 5 speakers (without sub woofer) for surround sound effect. Looking for decent speakers for around 20000 (tower speakers are not required). Kindly guide.
P.S. - I have a Yamaha 581 AV & Yamaha 315 sub - woofer
There are many brands available, you can look at Bookshelf type.....
If you are open to pre owned....here is a good deal within your budget and with 6 years warranty......it will easily match with the Yamaha AVR and you will enjoy a good movie + music experience...
Reasonable! 5.0 Mini Monitor speakers for perfect Music N Movies output - HiFiADS.com
Check if still available.....it will be ideal for your use and budget
