The quest for searching the ultimate value for money budget 4k TV started long back but as usual it's limited by the technology and big players playing big refusing to come down. This year is phenomenal in bringing the value proposition back to consumers. More and more companies stepping into volume market by introducing more bang for the bucks.
My search is pretty simple as mentioned in the title since my TV time is less and needed a good television for that particular time. Nothing more and nothing less. To choose, you need options.
There are two kind of options to choose from initially. Latest model or old model. Over a period of time the inventory need to be depleted to make way for the new items and they tend to sell at lower price. It's one of best value proposition but you need to check that new model is how much new and there is a possibility of old stocks with age problems. Getting value itself is gambling and i don't want to add one more odds into it. So I'm eliminating this option. So only newer models - 2018
The secondary question and the most important ones are - What are my options? First we take down all the available options and see if we can narrow down. If you have any other 2018 model from any company, Please reply back and we'll add to the list and discuss it's pros and cons.
Daiwa D55UVC6N Rs.36,999
Mi LED Smart TV 4 Rs.44,999
iFFALCON K2A Rs.45,999
Onida K Y Rock 55UIR Rs.52,990
Vu 55SU134 Rs.55,999
TCL L55P2MUS Rs.56,990
My thoughts about the models and it's value propositions will be discussed in the upcoming replies. Stay tuned.
