A budget projector in 40K?
Mogami Cables
nkchokshi
India
Guys , if any one can help me, with my projector req.
I am under tight budget and still need a projector, i have Bluray, and i want to connect with it, so need projector with HDMI in, and it should support HD content.
I have gone through some 800x600, and 1024x786, and 1280x800, projectors and i think i might be able to buy 1024x786 once. But still i want to know its a 4:3 screen size, so will it be able to display 16:9?
Also if you guys can suggest a good projector in this price range?
Thank you.
mshifi
hyderabad
if you are looking for a full HD projector, it may not come in your budget. You could look at a lcd projector which may get in your budget. Also do you have a dedicated room for viewing.
nkchokshi
India
Okay guys I found acer 5380bd in newegg, costs about 35k, but did any one orderd from there??
What about the power properties of it, in product description it says 110v-220v avc.
nkchokshi
India
How is optoma w311. Found out that the offer ended of acer. So again looking for options.
rayvonnee
Kurla, Mumbai
You should be able to find epson eh-tw550 for 52k in india. Though its only hd. Itsbquite decent. Or u have to buy internationally, but mind you ni warranty whatsoever. So choose a brand like acer or epson which has presence in india as well so incase of a problem you can service your product at least. In case of optoma that would be a problem.
Aquarian09
Hyderabad, India
If you r looking for a Full HD projector, there is no doubt about it that u will not get it within ur range.
you can try with 720p resolution(1280x720) projectors which might come in your range.
But, if you ask me, I would suggest you to increase your budget to 51,000 or 52,000 INR and get a Optoma HD141X
I was in the same budget range what you r now. i did research alot and kept track of all projectors for more than 6 months and finally decided to increase my budget and then waited for another 3 months and took the risk of getting Optoma HD141X from Amazon International from USA.
The only problem with international stuff will be warranty. I have spoken to Optoma India and they confirmed it. There will be no warranty valid if we import the projector. But however they can get the service done, they have expertise to do service in India, the only thing is no Warranty under any circumstance.
If you maintain it properly I dont think you will have to worry about it.
I got the projector from Amazon.com International shipping from USA. I am using Optoma HD141X from past 3 months daily. I confirm it that am using DAILY.
DAILY ATLEAST 3 - 4 HRS, and on weekends the projector will be running atleast 10hrs.
I did not face any problem till now.
Only thing we have to worry about is the power fluctuations. Get a 1KVA UPS for the projector and u will not need anything else. This is as my experience goes.
I am very happy that i took risk and waited for sometime to raise my budget and finally bought Optoma HD141X.
There is a thread exclusively for this projector. You can check what all the owners of this projector are saying about it. Everyone got it by International shipping from Amazon mostly.
The projector with the specifications of Optoma HD141X in India is not less than 1.2Lakhs.
We can get it at 52,000 including import & shipping fees, all inclusive is 52,000
the projector is actually somewhere around 35,000 if you can check it in Amazon.com
It's a great deal to grab.
Hope this info helps :)
Keep us updated about ur decision :)
Wish u good luck
Aditya
