Would a soekris r2r interest you? It's got preamp built in, rca and XLR out, ir reader and a display.Looking for a good preamp+Dac to go between BS Node 2i & Genelec G3s. XLR output is a must
Budget - under 50K?
Have atleast had 3 smsl amps in the past and using one currently. Never faced any issues ever...also if it's bought from a source like hifi express who offer a 2 year warranty ,there's some sort of peace of mind. However maybe I've just been lucky while others have had issues with SMSL.thanks for all who chimed in. So I am primarily considering the SMSL SU-9N, but the reports on the devices failing and general issues with after sales support is a bit scary. Any SMSL owners here - who can chime in with the reliability of the equipment?
I have been using an SMSL SU6 - DAC for little over a Year. Gem of a product. No problems yet. I purchsed it from https://shenzhenaudio.com/ . I am looking at buying/upgrading to another SMSL product soon.thanks for all who chimed in. So I am primarily considering the SMSL SU-9N, but the reports on the devices failing and general issues with after sales support is a bit scary. Any SMSL owners here - who can chime in with the reliability of the equipment?
Ideally want a DAC preamp. I was using the Node 2i with digital out to AL 6000a and the AL Dac was lot more neutral compared to the BS Node 2i, where you definitely hear bass bump. Want something as neutral or better than AL 6000a, hence was inclined towards the SMSL given the reviews about them being neutral or having no soundAlthough if your requirement is for a preamp only
if you are going with SMSL SU series, go with the pro version.Ideally want a DAC preamp. I was using the Node 2i with digital out to AL 6000a and the AL Dac was lot more neutral compared to the BS Node 2i, where you definitely hear bass bump. Want something as neutral or better than AL 6000a, hence was inclined towards the SMSL given the reviews about them being neutral or having no sound
Thanks for confirming that they are reliable enough to take a plunge.
What are the differences to be expected in SU 9 Pro vs SU 9N? This is what the company lists - I have no idea what is an XMOS or how much difference a "jitter elimination tech" adds (audibly). I do not need MQA.if you are going with SMSL SU series, go with the pro version.
better architecture, better DAC and better OP amp for a price difference i think of around 5 or 6 k is worthwhile.What are the differences to be expected in SU 9 Pro vs SU 9N? This is what the company lists - I have no idea what is an XMOS or how much difference a "jitter elimination tech" adds (audibly). I do not need MQA.
To me, the last difference in the list is the most significant: "Fully fitted color IPS display screen" vs. "Color IPS display screen".What are the differences to be expected in SU 9 Pro vs SU 9N? This is what the company lists - I have no idea what is an XMOS or how much difference a "jitter elimination tech" adds (audibly). I do not need MQA.
if it is a literal difference, then all the more reason to get the proTo me, the last difference in the list is the most significant: "Fully fitted color IPS display screen" vs. "Color IPS display screen".![]()
Also - SU-9 PRO uses the new ES9039MPRO DAC ChipWhat are the differences to be expected in SU 9 Pro vs SU 9N? This is what the company lists - I have no idea what is an XMOS or how much difference a "jitter elimination tech" adds (audibly). I do not need MQA.
Have you shortlisted any yet? How's the hunt going ?Looking for a good preamp+Dac to go between BS Node 2i & Genelec G3s. XLR output is a must
Budget - under 50K?
