Absolute Phase: IsoAcoustics Aperta Sub
Absolute Phase
IsoAcoustics Aperta Sub (Coming in the 1st week of Aug to India)
IsoAcoustics is on demo at Absolute Phase (Exclusive India Distributor)
Isoacoustics is available in Mumbai & Pune.
IsoAcoustics is proud to reveal the new Aperta Sub. With a sculpted aluminum frame and patented IsoAcoustics integrated isolators, the Aperta Sub introduces a new standard in acoustic isolation for subwoofers. The Aperta Sub decouples the subwoofers from the supporting surface to prevent the physical transfer of energy that excites the supporting surface, causes room rattle and disturbs your neighbors. The patented IsoAcoustics isolation also prevents the subwoofer vibrations from reflecting on the supporting surface and being conducted back up the subwoofer cabinet. Managing these reflections eliminates muddy bass smear and reveals greater clarity and definition.
The Aperta Sub has a low-profile design at 10.5” (265mm) wide x 11.5” (290mm) depth x 1.3” (33mm) height and is designed to be used with front firing and side-firing subwoofers that weigh up to 80 lbs (36.3 kg). Innovative shape allows the Aperta Sub to be positioned directly underneath the subwoofer cabinet without interference with the existing subwoofer feet.
With a large driver producing low frequencies, the subwoofer creates a large amount of energy that can excite the supporting surface, interfere with other audio components, and annoy your neighbors. The Aperta Sub provides a high degree of isolation and will clean up the muddy low frequency sound to reveal more clarity and definition. The unique patented isolators are directional and are designed to be positioned with the logo facing forward, to resist lateral deflection and oscillations, for greater accuracy and focus.
#isoacoustics #isoacousticsgaia #isoacousticsorea #isoacousticsdelos #isoacousticszazen #isolation #isolationdevices #isoacousticsaperta #subwoofers
#subwoofer #subwooferisolation #hometheatre #hometheatresubs #Bangalore #BangaloreCDB #Bengaluru #Chennai #Kochi #Pune #Hyderabad #Kolkatta #ahmedabad #surat #newdelhi #Mumbai #India
