Absorption panels, has anybody used them
hemanth.hg
I came across the following website http://www.uniquenonwovenco.in/acoustic-panels/cid-1224-270437 which sell many varieties of acoustic panels, they based in Bangalore. I called and checked on one of the panels, its is Sheetal Absorber Acoustic Panels, it is 2 ft x 4ft and costs around 1k, they seem to be priced similar to Aural Exchange.
Has anybody used these panels, any review would help a lot.
Thanks,
Hemanth
Hi Hemanth,
Have used some products from Aural Exchange. Looked at the link mentioned, strangely none of their products list acoustic properties or the details of materials used in manufacturing. I do hope you inquire in detail about these things before committing to purchase.
Good Luck
Thanks,
Hemanth
The first set of images on the link, seem to suggest these are acoustic foams.. They have very good absorption properties above 250Hz in the freq range.. Each absorption material has different absorption properties..
You may choose materials according to the issues existing in your room..
