Advice for HT in a budget of 2-2.5L
audio2025
india
Hello all,
i am in the process of upgrading my HT.
My present system is a bose acoustimass 10 which came the cubicle speakers presently working but not the bass module.
The system is over 12y which was paired to Denon AVR which is not working as well.
The unit will be in the living room with approx size of 250 sqft
Option 1 - replace all speakers and a brand new AVR +SUB
Option 2 - retain the bose speakers and invest in a AVR+ SUB
Option 3 - pick a good high end sound bar like sennihiser AMBEO max + sub woofer / JBL 1300 . Can the AMBEO max be paired with any other sub Woofer.
Option 4 - Any reliable independent service person in Chennai who can repair / service the acousitmass module.
Any good places in Chennai / Bengaluru where one get good auditions.
I would like to seek advise from experts on the different speaker / AVR which can be managed in this budget.
i am open to traditional 5.1/
Atmos is presently not possible there will be lot of civil work to be done for wiring as existing wiring is all concealed ; unless there are options for wireless atmos.
Thank you
Hello all,
Thank you
Denon 1800 with Klipsxh reference comes jnder your budget. Even polk also.
Its a decent budget.
I would suggest you replace your entire setup. Get a new AVR + Speakers and Sub.
Say a Denov AVR + Q Acoustics speakers. Should fit in this budget.
Thank you for your inputs, any place in chennai / bengaluru that you recommend where a demo is possible
For Denon AVR - contact ProFX in Chennai. They have a demo room.
PRO FX CHENNAI​
New No:202, Ground Floor, Opp to TVS, Annasalai, Chennai - 600 002​
+91 9444991182​
[email protected]
For Q Acoustic speakers - not sure. I have bought online from HiFimart.
My new year wishes to all members.
if one is purchasing the AVR / speakers and Subs online like hifi mart ; who handles the installation, service and support ?
Thank you
