Advice needed: Smart way to connect flat panel tv
Andrewx11
Hampshire
Hello
Does any one have advice on connecting a wall mounted flat panel tv with play station, dvd etc
The goal is to have cables in hidden in wall,
Also is there a wireless solution?
Help appreciated
If you are abroad and have sheetrock walls- you can cut a hole and run an hdmi behind the wall. If you are in india-- you can run the hdmi cable behind a casing.
An avr receiver- will take- all your inputs (dvd, PS3)- and you can have a single hdmi output cable going up to your TV
