bhagwan
Precisely - this is what I had in mind;I prefer spending hours finding a particular version of a tune I like than changing hardware/software for different formats or genres of music....
Use an I-Pod - keep your music on it - fast to find & easy to play.
Its quality is good & the cost is 100 % under check.
Do not get into this DAC / Card / UPB thing.
Unless you have larger sums of money to spend - the difference will not be audible & the entire exercise shall be futile; imho
I have done it - with a PC & cheap sound card [esi juli@] - volume control - TC Electronics etc.
Do not go down that path - it is not worth it.
an Oppo 105 will blow that set up to smitherines.:sad:
Only if you do the computer audio - meticulously will the result be good - else a waste of time. I have spent too much time & effort and money doing it - hence I say what I say;
Also used the EMU Card & USB Cable from Wireworld - Platinum / Siltech G-7 etc. etc. [this can go on forever - so I will control myself]
My suggestion is great [super] VFM & the interfece is brilliant too.
Never Play I-tunes on a Win PC - important to remember;
