All About Onyx and Jade
Metrum Acoustics™ Onyx and Jade are siblings of the renowned and award winning Pavane and Adagio digital to analog converters. Technology inherited from these top of the line DACs, make these mid-level DACs phenomenal value for the money and offer a very pure and pristine sound.
Both Onyx and Jade uses 2 of Metrum Acoustics' proprietary Transient DAC TWO chips per channel, making it a total of 4 very powerful DAC chips per unit for a fully balanced signal handling.
This R2R Ladder network combined with our renowned FPGA driven Forward Correction technology splits up the audio sample for each channel into separate data streams and each DAC chip processes a portion of the data in the most linear region of the DAC chip and then combined by our forward correction module to provide extraordinary signal ratio of -140 DB. Also, the dual mono design over the entire frequency results in an extremely high channel separation of 120 DB. This really is a pinnacle of DAC technology in the current time and definitely for some time to come.
While the Onyx is a pure DAC, one of the finest in the world, the Jade goes an extra mile by incorporating a fully balanced pre amplifier so the Jade can be used with any power amplifier to provide superb analogue sound without any hint of digital glare.
Jade follows a very clever technology for the volume control by directly altering the reference voltage in the R2R ladder rather than reducing the bits, so the sound quality remains at its best regardless of the volume level. No wonder many of the top class music creators including Grammy award winning sound engineers use Jade as the reference.
Both the onyx and Jade have Toslink (24/96), Coax and AES/EBU (24/192) and USB (24/384) Inputs and balanced output on XLR and unbalanced output on RCA
  • Balanced Digital to Analog Converter
  • 24 Bits Non Oversampling
  • Forward (FPGA) corrected
  • 2 DAC'S per channel in differential mode
  • 15 VA toroidal transformer
  • 110/115V AC 220/230V AC 60/50Hz
  • Input 1x optical, 1x coaxial 1x BNC and USB
  • Output 1x RCA Stereo Pair Single ended 2Volt RMS
  • Output 1 x stereo pair XLR: 4 Volt RMS
  • Frequency Response 44.1 kHz sampling 1Hz – 20 khz -1 dB
  • Frequency Response 192 kHz sampling 1Hz – 65 kHz – 1 dB 192 and 384kHz (USB)
  • Distortion 0.006 % THD
  • Noise Floor -145 dB related to 2 Volt RMS
  • Output impedance RCA 100 Ohm, XLR 100 Ohm
  • Sampling rate Optical 44.1 – 96 kHz
  • Sampling rate Coax and AES/EBU: 44.1 -192 kHz
  • Sampling rate USB 44.1 – 384kHz
  • Dimensions 290 x 250 x 60 mm
  • Weight 3.1KG
