Ambient Light Screen for Acer 5380 - Bangalore
techie_007
Hello All,
Some very useful information available in this section which I have been reading over the past few weeks.
I am in the process of setting up a budget projector setup at home. Havent been used to a TV for a long time (10 yrs+), so all watching is usually done on a PC. Now its time to get a proper screen for this setup.
Have tried using a friend's Qumi Q5 LCD portable projector, and liked the 50-60 inch it projected on my wall.
* The projector will be an Acer 5380 720p ordered from the USA.
* Projector will mostly be used for movies and TV shows. 480p/720p content.
* Placed in the living room of my smallish flat, no dedicated space available.
* Content will be streamed to the projector with a Chromecast from the media server, so only power needed.
* Not an audiophile, so the level speakers I have will do for now. Speakers are the Microlabs/Circle Arko bookshelves: http://www.hifivision.com/reviews/22413-cirle-arko-microlabs-solo-6c-100rms-active-speakers.html
* The only decent space I have to use as a screen is around 80 inch wide, basically the entrance alcove of a rectangular living room, so a 72 inch screen will be needed. Unfortunately walls here are yellow, making some sort of screen a must. Projector will be placed around 10 ft from the wall, with viewing area being sofas around 14-16 feet away.
* Projector will be used mostly after work, late evenings on weekends, with the PC monitor used for daylight use. However, may want to use it during daytime occasionally too.
Questions:
* Since the room is a living room, there is ambient light, even with dark curtains, plus the walls are light yellow with white ceiling + light floor tiles, so expect lots of reflected light too. In this case, it appears that a gray screen would be better than a white one. Any suggestions on where to get one on a budget? Also, any disagreement on grey screen?
* Ceiling mount wont work since its a rented place and the alcove is to the side of the room, so planning floor mount. There is also a beam in the way on the ceiling, causing more issues.
Right now, I am thinking an upside-down ceiling mount with a heavy base welded to it that can be placed on the floor.
Anyone used something like this? How to calculate height of projector from floor based on seating height??
Heres a link to a picture of the wall: https://www.dropbox.com/s/2n3jgznpxeuyd7c/2014-06-12 21.56.33.jpg
Limited space unfortunately.
What did I miss? Look forward to suggestions and screen contacts.
Bumping.... Any recommendations? Projector should be here next week :)
What size of screen are you looking?
Liberty 8*6 120 inch 16:9 screen is 10k
Liberty grandview same is 15k
For budget u can go for screentechnics, i'm using screentechnics projector screen it is quite good for the budget it starts from 4k to 6k for the same size.
Screen Technics :: Projectors Screens :: Projectors :: Ceiling Mount Kits :: Audio Video Solutions
Floor mounting the projector is not advisable if you have kids.
No kids :) planning to get it mounted on a heavy base. Screen size, my wall section is Limted to 80inches width.
@subbubusk:
Checked out the website. From a width perspective, only thing that'll fit is the 4x6 screen. I am assuming I can buy the instalock type and only open enough to give me 16:9? Please confirm.
@subbubusk:
yes you can stop the screen till the height you want to see.
So the projector is here..... :) looks good on a wall. Will post further impressions after I get a basic insta lock screen.
Hi Tech
How did you get your projector? What was the total damage to the pocket? And finally what are the initial impressions of the projected image?
I know ...too many questions....but kindly excuse the curious mind of a prospective buyer for the same projector for the same reasons because of which you got the projector.
Bobby
@bobby0909 this was carried over from the US by my parents who were luckily travelling there for the summer. Had it delivered to their address in the US and brought back in carryon in its original box. Cost was $450, came to about 28k or so I think. Shipped to India directly from Amazon should be in 35-40 range.
Initial impressions are very good, though done only 6-7 hours yet, projecting on a yellow wall. Trying to do a DIY floor mount, then will add a screen. Will add more pics of the image as well. My first projector, so no complaints as such. Also need to see if my existing 1kva UPS will support it. Got a PC also connected to it, so let's see.
