newtoaudio90
Hi guys
As some of you may know I have been waiting on a new system for some time for my PC.
Today I got my PSB image B5s with topping TP20 working and its great
Anyway- random question. I have never had speakers of this level attached to a PC (infact have never had speakers and amp running to a PC).
That being said- seeing you can adjust volume with both the PC controls AND by turning up the amp how high would you leave the amp set?
I figure- turn it up most of the way and then control with the PC?
Would leaving the amp turned down a little be a 'safety mechanism' in that I would be less likely to overdrive the speakers into clipping (seeing my amp is only 20watts - more likely to damage them from low power than high).
Can clipping occur if i turned the speakers up to full through the PC BUT turned the amp down a little so it cannot go as loud int he first place?
