Amps Suggestion. Kindly Help. URGENT
dheep4225
India
I'm looking to get advice on what the best amp or amps would be for the setup below in my Ford Figo.
JVC KW AV50 DVD/CD/USB Receiver or Sony XAV 601BT
Polk Audio MM6501 in front.
Polk Audio MM691 in the rear.
Polk Audio DB1212 12'' Subwoofer Enclosure.
Can I use Polk Audio MM6501 both in front and rear?
I'm into classic rock and hard rock... so I'm looking for sound quality with punchy, accurate, and clear bass, mids, and highs. I don't listen ridiculously loud most of the time, but I would like that capability... and I definitely want clean sound.
