Another affordable option for projectors - 480P - check out pictures below
arnprasad
Vijayangar, Bangalore
I have a 720P Acer projector and i can definitely make out the differences but given the MRP ratio is 1:10 or more, I dont mind this projector as well particularly if used for kids gaming.
This ones around 3500 if u use all the discounts and offers during Dasara sale;
UC 40 PLUS LED PROJECTOR: Amazon.in: Electronics
In the below image I have used my own grandview 15K 10feet screen, but plan to buy my nephew the below..which aint bad for 3K
Inlight Map Type Projector Screen, 8 Feet x 6 Feet: Amazon.in: Electronics
Expecting many thanks! 97 now....will cross 100 tonight? :)
Looks good. Planning to buy one for TV viewing. Is the output good for HD channels .
Sent from my XT1031 using Tapatalk
it all depends if u owned a better one before..am sure its passable....again for 8000 rupees you are getting 10 feet.no harm in trying.got very little to lose. brightness on lower side though.
Do you know the min. distance required from the projector wall? I have a spare room which I am thinking of converting into a HT room. However, the wall is only 10 ft long, so that max distance I can get is around 9 ft. Wondering if this is sufficient to get a reasonable size (say around 100ft diagonal). I will be happy with a 90-100 ft size.
Thanks in advance.
Best,
APK
Thanks in advance.
Best,
APK
yeah getting 8 feet diagonal is possible
