After going through your posting, I almost forgot whatever little knowledge I had regarding the power cord and connectors.Just curious - what's the known reason/science behind these cords.. The bridge rectifier inside had very narrow diode terminals but that's on the low voltage side.. the transformer itself has copper wire that's not particularly special.. the power wire itself is connected to some kind of ordinary terminal block.. Has anyone opened their system and looked at the transformer lamination EI - they are usually of ultra crappy quality because they get wound over ..
ergo.. any datasheet/spec for these cables..
for 1800/, that's almost the cost of an intel cpu these days.. or 90m of 14 AWG.. (btw that link has a Cable Chart so you can size/calculate the correct AWG for your wires)
Buy Standard 90 Meter Single Core PVC Insulated 1100 V Flexible Cable 1.5 Sq mm Online at Bestomart
Buy Standard 90 Meter Single Core PVC Insulated 1100 V Flexible Cable 1.5 Sq mm in India at Bestomart. Shop Electrical, Wires & Cables range from Bestomart.www.bestomart.com
How thick do you want your wires - I'll sell you some and a time-share on my new oscilloscope? (2000x20 ppl = 40k)
if our arteries are narrow, does it mean we don’t need clean blood ? I bet you change all those wires you mentioned and sound will surely get better. But we can only change what we can change. Power cords are easiest thing to change.Just curious - what's the known reason/science behind these cords.. The bridge rectifier inside had very narrow diode terminals but that's on the low voltage side.. the transformer itself has copper wire that's not particularly special.. the power wire itself is connected to some kind of ordinary terminal block.. Has anyone opened their system and looked at the transformer lamination EI - they are usually of ultra crappy quality because they get wound over ..
Hi,Just curious - what's the known reason/science behind these cords.. The bridge rectifier inside had very narrow diode terminals but that's on the low voltage side.. the transformer itself has copper wire that's not particularly special.. the power wire itself is connected to some kind of ordinary terminal block.. Has anyone opened their system and looked at the transformer lamination EI - they are usually of ultra crappy quality because they get wound over ..
electrons don't flowTo top everything the Naim NAC A 5 cable even had arrows marked showing the direction which presumably electrons flow better (not faster or slower, just better on Naim equipment!)
I concluded my little experiment consoling myself that science and religions have been at it for centuries with no clear winners, so I can maybe in the meantime .... just enjoy the music?
Thanks for correcting my mistake. I am getting flashback memories of my high school physics classes! (I mean it in a nice way) Loved the Diwali cracker and human behavior example and the temple queue panic examples.electrons don't flowthere's no net transfer of electrons like water molecules.. it's like a Tirupati temple queue packed with people. When a cracker goes off at one end of the queue, the blast frightens people who will push away from that noise and then they realize "oh it's just a cracker" so they go back to doing whatever still in the queue.. but that pulse of panic travels the length of the queue.. with electrons, the probability distribution that tells you where the electrons are at any given time will change which is equivalent to flow of energy
Think of it like a jam packed Tirupati queue where each electron is standing in it's place all the time except during the cracker blast when it shifts in panic transmitting that fright to the next electron.. material defects don't prevent the electron from transmitting fright/fear unless the material is torn apart
has great intuitive explanations of most electronic concepts http://amasci.com/amateur/transis.html
Hope this doesn't ruin you appreciation of music..
as in?What about the directionality?
Sorry, I dont understand what you mean ....Just curious - what's the known reason/science behind these cords.. The bridge rectifier inside had very narrow diode terminals but that's on the low voltage side.. the transformer itself has copper wire that's not particularly special.. the power wire itself is connected to some kind of ordinary terminal block.. Has anyone opened their system and looked at the transformer lamination EI - they are usually of ultra crappy quality because they get wound over ..
Hi Raghu,Directional cables are usually ICs.
Depending on how the shield/drain-wire is terminated determines the direction of connection.
If I remember correctly, the source side (upstream) is terminated and destination side (downstream) is floating.
No idea about directional speaker cables; maybe they have some filter/choke element.
Raghu
Time perhaps to delete the 'G' ?I tried connecting them in either direction but could not hear a difference . My hearing is not what it used to be.
well.. design is optimised for use with Naim Audio amplifiers and any loudspeakers by ensuring that its capacitance, inductance and resistance are entirely compatible.As in the Naim NAC A5 cables. They are marked with arrows - presumably indicating the direction for wiring Amp to speakers
Time perhaps to delete the 'G' ?![]()
I don't own a Siglent 1104XE or 1204XE or Rigol, 1GSa/s 200mhz 4channel - shipping+duty are pretty expensiveSomewhat off topic, but since you have referred to it ... would love to know specific details (Brand & Model Number) of yr new O'scope
I don't own a Siglent 1104XE or 1204XE or Rigol, 1GSa/s 200mhz 4channel - shipping+duty are pretty expensiveToolBoom during xmas sells them with free shipping but you need a card etc or wire transfer.
(Hence my shock at the cost of Mr.Murthy's power cables and praise for Mr.Murthy.. unless Mr.Murthy rolls his copper himself from ingot copper.. and draws them out himself.. Indian manufacturing needs to be subsidized - what i dislike is some clever cog, buying from China/elsewhere, assembling it here and sticking on a huge markup with clever marketing designed to fool Indian ears - unless of course clever cog donates a significant chunk of his loot to indian schools for o'scopes)
Regarding the speaker cables: you'll have to ask whoever took that/my image out of the 'Murthy' thread and created this one.. he has his own ideas on what I was trying to say and thought my posts to be not relevant to Mr.Murthy's cables.
Has anyone here done a double-blind study?
Again, some may think so. In reality, there are many methods for determining preferences and accuracy of audio components. Measurement data is far more accurate than one's ears. DBT is simply one procedure. DBT does a great job in removing bias from comparisons. However, DBT does not imply that differences do not exist, only that these differences in this test, are below the levels of general audibility.
Many people feel that the true character of individual components is only realized after long term listening and living with the component in question. These people would argue that it takes time to fully appreciate or understand certain subtle differences that exist in various audio components.
Thanks.well.. design is optimised for use with Naim Audio amplifiers and any loudspeakers by ensuring that its capacitance, inductance and resistance are entirely compatible.
I don't know anything about the amp or the speakers.. what you want is the service manual which will have the schematic.. (the assumption being the schematic is a true representation of what's present)
Usually you don't need to bother about wire directionality - when you connect a voltage source to a wire, which is a metal, there's an ocean of electrons between the two points.. and conduction of energy is taking place within that ocean NOT within the material itself.. that is, metals have a crystal lattice to hold the wire together - each atom linked to the next atom by strong chemical bonds enhanced by the face structure (the alignment/composition of atoms in a cube) - this gives the wire mechanical strength BUT CONDUCTION of electrical energy is taking place in the ocean of valence electrons.. so either direction is okay UNLESS the wire is modified in some way, for marketing purposes or otherwise - they could attach a diode to one conductor for whatever reason..
Imagine it like this, lets say planet Earth, is an atom.. the valence electrons are in the cloudy upper atmosphere busy transferring energy through waves motion.. what's happening on the ground or lower atmosphere won't affect it..
What he means by RLC is impedance matching for power transfer
I did some googling - apparently - shielded cables so there's a wire mesh around the signal-wire that needs to be grounded and the path to ground is provided at one end.. (not at both ends) ergo the directionality.. meaning that if you reverse, your shield-mesh won't be 0V.. just test with your multimeter on the lowest resistance setting(smallest current)Thanks.
I do use these cables with a Naim Nait 5i. I have attached a picture showing the arrow mark on the cable. (Can’t figure out why they are upside down, sorry). I heard that Linn also Mark their speaker cables with an arrow.
But...They do sound good together.
Hi @veekm,I did some googling - apparently - shielded cables so there's a wire mesh around the signal-wire that needs to be grounded and the path to ground is provided at one end.. (not at both ends) ergo the directionality.. meaning that if you reverse, your shield-mesh won't be 0V.. just test with your multimeter on the lowest resistance setting(smallest current)
It works like a Faraday Cage.. any Radio frequency signals/waves (think computer mouse movement) will induce currents in your signal wire and you'll hear an awful hissing/buzzing sounds at quiescent (when there is no audio being played) so with a metal cage around the wire, any induced emf gets 0'd to ground - if it's connected to ground
In differential signalling, they send an inverted copy of the signal across the 2nd wire and use a op-amp to reject anything different so shield's not that important.. (ethernet twisted pair uses that) but again.. it's up to the designer/schematic.. we can make an educated guess but if he's a jerk... mebbe he's doing some marketing in there.. (it's not technology wise important)
This has nothing to do with crystal lattice of metals and stuff - often companies will scrimp on parts by avoiding using an extra component in the bill of materials and then market this as a 'feature' to sound complicated/cool
