Antenna required
For the temp do the good ole trick. Try sticking a wire in the fm slot and extend it. You should get reception. :) There are radio kings here who will advice better than me !
Hi..
where can I get a new FM antenna for denon x520bt.I seem to have misplaced it .
Are you looking for something indoor or outdoor? Indoor antennas are not that effective. You can just use a wire to DIY to buy something readily available. If you are close to radio stations, simple wire works fine too. Get a wire of about 3mtr and plug it in. If the wire can be placed vertically near the window or outside the window, it is better.
Here in Ahmedabad, you can get a genuine Yamaha Antenna for around 2.5 k which would fit in your denon, I too had to purchase it
