Any advantage of Power Sub-woofer against Passive
Onkyo HT-S3700 (Package) has a 130 W Passive Sub-woofer (Not built in Amplifier)
I took a demo of this setup and the Bass punch from this passive sub is good enough for a standard living room.
Later all speakers can be up-gradable with Bookshelf or Floor standing, except the Sub.
Do I really need to go for Power Sub-woofer?
Any advantage of Power Sub-woofer against Passive.
Thank you.
Thank you.
Power is the advantage.
In case you feel the need to upgrade and it is likely that you will, a powered sub gives you more flexibility with regards to replacement. Also a powered sub takes over the lower frequencies amplification from the receiver, so the receiver can use the available power for the mid and high frequencies.
