Anyone got this ? - Sanyo XT-65A081U 65in 4K UHD LED android TV
desertfox
Vijayawada
I’m about to get this. It’s 70k on Amazon - Sanyo 165 cm (65 Inches) 4K UHD LED Smart Certified Android TV XT-65A081U (Dark Grey) https://www.amazon.in/dp/B07HW215GJ/ref=cm_sw_r_cp_api_i_klI3CbXGZTT6C. Manufacturer is Panasonic India. Any downsides to getting this one ? My room isn’t a fully dark room. Some light leaks from the doors and windows/curtains.
Thanks in advance for any help you are able to provide.
Wait for 2 to 3 months.all Chinese will be floating towards india due to trade war.meight get hisense ULED XD h9f which equal to qled and oled in just 70k.after all 4k is useless without jio gigafinar.
And if you are in hurry try iffalcon qled in just 90k after any old tv exchange on Flipkart
wanted to know if you purchased this product? and feedback would be appreciated
