Anyone tried using a Car HeadUnit as home CD player ;-)
Yup, even my friend also confirmed me the same. I'll just get a 5amp transformer and that would work fine I think. Shouldn't cost more than 400Rs according to my friend. He talked about Milton or SRC transformer, any idea about them?
All the amplification will be done by the AVR.
I have seen guys at car stereo shops using "Speedking" 5 Amp/12V transformers. They play it at decent volumes with speakers directly connected to the HU. Since you are only going to use the preouts, I guess a 5 Amp PSU should more than suffice.
If you are going to use only the pre-outs and never connect to speaker wires then the power at the 12v line may not even draw 1 ampere. you can try out with a standard multimeter to verify. do it in car itself on the switched wire without connecting speakers.
