Audio configuration problem for my computer and itunes?
adrienne224
Texas
ok, everytime i try to run Itunes, i get this error message that says "itunes has detected a problem with your audio configuration" what does this mean? and how can I fix it! please someone help!
"iTunes cannot locate the CD Configuration folder, so you cannot import or burn CDs and DVDs. This folder must be in the same directory as iTunes." All you have to do is go to your drive C: and locate the iTunes folder from your Program Files. Then you must cut that folder and paste it to which drive you installed your iTunes, and it's fixed. Quick and easy.
