Audition Polk Speakers
Not only with old hindi music , I have found polks dont gel well just with vocals without instruments. Just my ears. :)
RTi are pretty decent for the price, but just be aware that they are known to be a bit bright over extended hearings. They will be just fine for movies, but I will thing again if you plan to listen to music for long periods.
I own the TSi200s. I'd auditioned both TSi and RTi. Yes, the Polks (both series) are a bit bright. Personally, I found the TSi more suited to my requirements than the RTi.
Audition both, and go for what suits you.
+1 to both.
I have auditioned Polk Audio Rti and Tsi series very recently and found them too bright to my liking. Though Jagjit Singh sounded quite nice through them.
Amar,
First welcome to HFV
You can look at the Polk TSi series which would match your budget
Thanks mate.
I auditioned Tsi 400 today. Since i did not listen to Tsi300 so i am not sure what will be the differnece between 400 & 300. is Low bass is the only differnce then i am going to have sub for that. below is what i listed out as per my budget.
Front: TSi 400 or Tsi 300
Rear: Tsi 100 or Rti1
Center : CS10 or Csi A4
Sub : Polk 125 or Yamaha 315.
Now the confusion is whether i should really go for Tsi 400, which actually adds low base. but since i am going to have Sub as well. do i really need Tsi400?
i was thinking that, i should upgrade the Center to Csi4 and lower down the Fronts from Tsi400 to Tsi300.
Also, i got mixed reviews for Polk Subs. My budget for Sub is around 15-20. Yamaha 315 fits into this. Please suggest.
My room size is small, 10 X15. Receiver, x667BL
Amar
Dear all,
Need some expert advise+
i am a newbie member
i have bought sony strdh820 3d reciever and looking for speakers
my main purpose 100% for movies not for music. my bugget is 50k
i have shortlisted few speakes
Front: polk TSi 400 , Tsi 300 or rti a7
rear : Tsi 100 , Rti1 or tsi200
Center : CS10 or Cs20
polk speakers is good for movies .my room size 20 X13
no a/v shop avialable in our city so i cant any demo of the speakers
please suggest me which speakers is online buying
i did not get chance to hear because no shop in our city .so please suggest me good speakers for theater experience
navdeep
what is your budget/size of your room if you can provide that I am sure there are many Gurus in this forum who can give you good suggestions
IMHO dont buy anything just for the heck of it or because someone says it is good. You have to experience it so try and reach out to some friends where ever you are staying and listen to various brands before you take the plunge
Hi Navdeep,
Sorry for the delayed response. Yes I have auditioned both RTi and TSi series and IMHO RTi series are the superior lot. Having said that TSi is not bad at all. :)
If you are keen on Polk please try Any of the RTi Series A5/A7/A9 they are good
