AV receiver suggestion.
delhi
HT room size 10 x 12 sq feet
Current setup
AVR YAMAHA RXV677
B&W M1
SVS SB-1000
I want to change yamaha avr, I heard B & W are of brighter side and gel with warmer avr and require high watt oer channel to make them shine, correct me?
Suggest me a new avr for my setup.
Movies/ Games 60%
Music 40%
You can consider Denon Avr x2600. It should be enough to handle the power requirement of M1. M1 usually requires 20W - 100W into 8Ω on the unclipped programme. x2600 has a power rating of 95W at 8 ohms, (20 Hz - 20 kHz, 0.08% 2ch Drive).
Coming from Pioneer, Denon, and Marantz- I would say Marantz. You can consider the SR series according to your budget. But, it is generally understood that under the hood, both Denon and Marantz are similar - with Marantz being on the warmer side.
