Hello FM Lords of HiFiVison,
After being a silent spectator of HifiVison posts in HT & Speakers Forums for more than a month, doing my share of research, going through countless Youtube Videos and blogs around Audioholics, Crutchfield, Chris Majestic, Oobarpad etc, I propagated my decision in the below flow =>
Existing TV Speakers => 2.1 Soundbars (Polk Audio Signa S2 (10.7K) => Samsung Q800T 3.1.2 Soundbar (to use QSymphony) => HTiB (Yamaha YHT 1840 , 3072IN) => Build Separates gradually over time (AVR + Front LR and Center first, followed by Sub and Surrounds).
I loved the beautiful journey shared by @gourav and @Deerajgowda to achieve a similar setup I'm planning.
I own an MAudio AV40 2.0 Studio Monitors and these beat the TV Speakers fair in music but lag in dialogue delivery due to lack of Center Channel.
Below is my current Setup :
Below are my Room location and dimension details :
Below is my Budget :
Considering this is an expensive project, I wish to build a 5.1. setup gradually in phases.
Phase 1 (Within a month - AVR + Front LCR) : 1 L
Phase 2 (Witin 6 months - Sub & Rear Surrounds) : 50K
My TV doesn't currently support Dolby Atmos, but I'd love to have the AVR with 7.2 if possible in the Budget so that I can get a nVidia Shield Imported in the future and add the remaining Speakers if possible. But for now, I have never owned even a 5.1 Setup at home so I'd be even happy with the same.
I have Pet cockatiels who stay with me in the same room, so I dont increase the Volume by more than 30%. So the priority is to have a System that can give good Clarity and Enough Bass at Low Volumes. Movies/Music Usage Ratio => 60/40
Considering the Bedroom Size being small (3.5 m X 4m X 2.65m), I have shortlisted the below options for now :
I'm leaning towards Option 2 where I'm getting QAcoustics 3020i for 25K, 3090ci for 18K. Yet to get a Quote for Denon X1600.
I'm also open to Used Setups (If generous FM among you with an urge to upgrade can help me out - as I don't trust OLX for HT components at least)
I have attached an Excel Spreadsheet with more details and a couple of Wide Angle pics of the room for reference.
I have spoken to Mr Amit from Indiq Audio and he suggested Diamond Mishra's with Denon AVR as a start, but those L+R speakers are way too big for such a small room of mine and within that range, I'm getting the entire LCR from QAcoustics - Option 2 above). That's why QAcoustics excites me as that gives me the much-needed approval from Home Ministry (As I'll just have to replace the AV40 Speakers on my TV Stand with QAcoustics LCR.
I have not auditioned anywhere till now due to pandemic risks.
@fLUX @OM_2K19 @Prodigy @ktks1 @square_wave @Mahi @sud98 @rksingh1
If Auditioning is a must, I'll need your assistance to get more details wrt Demo rooms in Bengaluru.
@Love4sound @arunkvivek @elangoas @prateekatasniya @Vinod.R @Mayank Shah @alphacentury100 @DB1989 @sud98 @rpmahale @rsjaurr @raghupb
@efernand1 @amrutmhatre90 @Yogesh @srinisundar @argho @k-pad
I'll also need your expert guidance to make an informed decision.
Thanks a lot in advance
Samsung The Frame 2021 55"4K QLED 120Hz with HDR10+,(doesn't support Atmos & Vision) 40W speakers, has HDMI eARC and HDMI 2.1 ports (got last month) |
PlayStation 4 (FIFA addict once, Used to run Netflix and Prime in 1080p until I bought Samsung QLED as it supports native 4K for these. |
Windows 8 PC (AMD FX8340, nVidia GT750 Graphic, 32G Mem - Use for regular browsing on TV via HDMI - Supports [email protected]) |
M Audio AV 40 2.0 Studio Monitors - 40W Total - To listen to Lossless Audio with PC - didn't buy DAC to connect to TV, For Netflix - still use TV Speakers |
Room Type | Bedroom in a 3BHK Flat on 4th Floor in a Gated Community. TV in front of a 2m X 2m (6.5ft X 6.5ft) Double Bed |
Room Dimension to consider (Left Cupboard to Right Wall) | 3.5m X 4m X 2.65m | 11.5 ft X 13 ft X 8.7ft |
Room Size (Wall to Wall) | 3.5m X 4.5m X 2.65m | 11.5 ft X 14.5 ft X 8.7 ft |
TV to Viewer (Me) Distance | 3.2m | 10.5 ft |
Speaker to Viewer Distance (L+R, Center) | 2.8m | 9.2 ft |
Subwoofer Placement | 2.8m | 9.2ft | Preferring to Put Below Left Front Channel in a Cabinet on the TV Wide Stand (Not sure yet) |
Rear Speaker Placement | May Place on Back wall on top at 8 ft height OR at the Bed Headboard (Stuck against the back wall no gaps ) at 3 Feet Height |
TV Stand Specs | TV is wall mounted, Below the same, I have an Open TV Cabinet of 6ft length X 1ft width X 2 ft height). |
Items | Option 1 (Cheaper) | Option 2 (Mid) | Option 3 (Mid to High) |
AV Receiver | Denon 550BT | Denon X1600H | Yamaha RX v585 |
L+R Speakers | Taga Harmony Platinum B40 | QAcoustics 3020i | Polk Audio S20 |
Center Channel | Taga Harmony C40 | QAcoustics 3090CI | Polk Audio S30 |
SubWoofer | Taga TSW-200 | QAcoustics 3060i | Polk Audio HTS10 |
Rear Speakers | Taga Harmony TAV-806s | Polk Audio OWM3 | Polk Audio S10 |
